Call Forwarding Issue
lewiskeyte
Hi, I'm having a problem with call forwarding on a CME. Cleaned up config attached.
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
CME 10.5
Mix of SIP and SCCP phones
We have a main line, 2100, that is assigned to a single 7942. This forwards to a hunt group, 2998, for the office manager and receptionist. This seemed to be the easiest way to allow them to forward the main line to a mobile if the whole office will be out during the day.
ephone-dn 1 octo-line
number 2100
label Main Line
description Main Line
name Main Line
call-forward busy 2998
call-forward noan 2998 timeout 3
voice hunt-group 1 parallel
final 2999
list 2112,2113
timeout 8
pilot 2998
description Ops
voice hunt-group 2 parallel
list 2110,2111,2112,2113,2114,2115,2116,2117,2118,2119,2120,2121
pilot 2999
description Whole Office
When a call comes in via PRI to the main line, it forwards correctly to the hunt group. When a call comes in via PRI to someone's direct line, it rings twice and disconnects without forwarding. This occurs on both ephone-dn and voice register dn extensions.
Calls that come in from other CMEs via SIP trunk behave correctly for both the main line and the direct lines.
I'm not seeing anything obviously problematic in the debugs - I've looked at isdn q931, ccsip messages, and dial-peer. Let me know what other debugs would be useful to provide.
008842: Jul 11 02:20:18.355: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x3A99
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18389
Preferred, Channel 9
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x0183, '006565719169'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xC1, '80262112'
Plan:ISDN, Type:Subscriber(local)
008843: Jul 11 02:20:18.355: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0xBA99 callID = 0x007A switch = primary-net5 interface = User
008844: Jul 11 02:20:18.367: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xBA99
Channel ID i = 0xA98389
Exclusive, Channel 9
008845: Jul 11 02:20:18.415: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0xBA99
008846: Jul 11 02:20:26.423: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xBA99
Cause i = 0x8090 - Normal call clearing
008847: Jul 11 02:20:26.667: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x3A99
008848: Jul 11 02:20:26.667: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xBA99
009745: Jul 11 02:47:16.147: //111667/9CA8CEA68081/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:2112@10.37.201.21:49184 SIP/2.0
Via: SIP/2.0/TCP 10.37.254.1:5060;branch=z9hG4bK12A815D8
Remote-Party-ID: <sip:006565719169@10.37.254.1>;party=calling;screen=yes;privacy=off
From: <sip:006565719169@10.37.254.1>;tag=9508C050-19E2
To: <sip:2112@10.37.201.21>
Date: Mon, 11 Jul 2016 02:47:16 GMT
Call-ID: 9CAB3FDF-464811E6-9EE4E1D5-FF1CB56F@10.37.254.1
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 2628308646-1179128294-2155968698-4192284032
User-Agent: Cisco-SIPGateway/IOS-15.4.3.M1
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1468205236
Contact: <sip:006565719169@10.37.254.1:5060;transport=tcp>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 2963 7474 IN IP4 10.37.254.1
s=SIP Call
c=IN IP4 10.37.254.1
t=0 0
m=audio 22530 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
009746: Jul 11 02:47:16.155: //111667/9CA8CEA68081/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Mon, 11 Jul 2016 02:47:12 GMT
CSeq: 101 INVITE
Server: Cisco-CP7841/10.1.1
Contact: <sip:9CDC-2549@10.37.201.21:49184;transport=tcp>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Supported: replaces,join,sdp-anat,norefersub,resource-priority,ext
ended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-6.0.2,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Content-Length: 0
009747: Jul 11 02:47:16.223: //111667/9CA8CEA68081/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:2112@10.37.201.21>;tag=e0d173e589ee4ef778808037-678e1429
CSeq: 101 INVITE
Remote-Party-ID: "J" <sip:2112@10.37.254.1>;party=called;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-6.0.2,X-cisco-xsi-8.5.1
Content-Length: 0
009751: Jul 11 02:47:24.231: //111667/9CA8CEA68081/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:2112@10.37.201.21:49184 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1468205244
Reason: Q.850;cause=16
Content-Length: 0
009752: Jul 11 02:47:24.235: //111667/9CA8CEA68081/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Mon, 11 Jul 2016 02:47:20 GMT
CSeq: 101 CANCEL
Content-Length: 0
009753: Jul 11 02:47:24.243: //111667/9CA8CEA68081/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
Content-Length: 0
009754: Jul 11 02:47:24.243: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:2112@10.37.201.21:49184 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
11 Replies 11
lewiskeyte
Noticed in a couple other call forwarding threads people were asking for debug voip ccapi inout, so have attached that as well for a failed call.
Hello Lewiskeyte,
Did you find a solution for that ? ..
I revised your configurations and the debug outputs for both ccsip and voip inout .. and I have no clue why the CME sent a Disconnect message through the Q931 , or CANCEL message to 2112 ..
From the ccapi output , i can see the redirection to 2100 :
009873: Jul 11 04:49:37.735: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
type=6 Original Called Number=2112, Called Number=2112, Calling Number=006565719169, Calling DN=-1 Calling Id=112017,
Redirect Number=2100, Redirect Reason=2
but then a disconnect message with normal clearing :S
009910: Jul 11 04:49:37.735: //112018/AFCA37B88083/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
normally for such cases , we should see an error like 302 Moved Temporarily .. or any message at least ...
one small notice .. i didn't find any inbound dial-peer for the PSTN .. like :
dial-peer voice xxx pots
incoming called-number .
direct-inward-dial
If you have an update , please keep posting on it ..
Thanks A lot,
Ahmed Salah
Hi Ahmed, no solution yet. I will try adding an incoming dial-peer and see if that helps.
As temporary fix, I've added the following rule so that calls to any DID go to the main line. All calls forward as expected with this in place, just like any call to the main phone number.
voice translation-rule 1
voice translation-rule 2
rule 1 /8026\(21..\)/ /2100/
voice translation-profile INCOMING_PSTN
translate calling 1
translate called 2
voice-port 0/0/0:15
translation-profile incoming INCOMING_PSTN
bearer-cap Speech
Hi, I've added an incoming dial peer but no luck.
dial-peer voice 12 pots
description Inbound PSTN
direct-inward-dial
Are there any other debugs you'd like to see?
One thing that is different with this setup compared to others I've done - when someone calls out from their extension (to a mobile phone for example) the main line number is displayed, not their extension. I was thinking maybe the forward process passes a number to the IDSN that it doesn't accept, but if that was the issue I would think all forwards would fail, or we would get a different code. Just thought I'd mention this.
can you provide a "show call his voice brief" for a failed call ? ..
and for that specific ID , do "show call his voice id XXXX" , where XXXX is the output from the "show call his voic brief" on the top left ( 4 characters ) ..
for the other problem , this is related to your carrier ( PSTN ) may be it is expecting the correct type and plan .. as some carriers don't like the "unknown" to be sent ..
try to modify your Outgoing translation "OutgoingForwardExternal" , and you may do a specific one for testing with your mobile ..
like :
voice translation-rule 3000 rule 1 // // type any national plan any isdn
voice translation-rule 3001 rule 1 /^21..$/ /08026&/ type any national plan any isdn << i don't know the mobile numbering plan for this country
voice translation-profile Outgoing_NATIONAL_TEST
translate calling 3001
translate called 3000
Working on this - here are the debugs without this changed.
Have tried with this config - same behavior:
rule 1 /^21..$/ /8026&/ type any national plan any isdn
dial-peer voice 10 pots
description Outbound PSTN
translation-profile outgoing Outgoing_NATIONAL_TEST
destination-pattern 8T
port 0/0/0:15
Edit: Realized this was to fix the outgoing number issue. Don't have someone onsite at the moment to try calling out, will test tomorrow. My OutgoingForwardExternal rules were necessary to hairpin forward an external call to an external number. Might not be exactly correct but that's why I had the rule there. FYI the country is China in case it matters.
just , make sure to change the number to your appropriate numbering plan :
rule 1 /^21..$/ /xx8026&/ type any national plan any isdn
or change it to international format :
rule 1 // // type any international plan any isdn
rule 1 /^21..$/ /868026&/ type any international plan any isdn
apply this to international dial-peer and test ...
Suresh Hudda
Configure below command under "voice service voip" and check once.
    no supplementary-service sip moved-temporarily
Suresh
Hi, have just tried that, getting the same behavior.
In fact, entering that command appears to also break calls that come in from another CME, not just the PRI line.
Either way calling the main line works as expected.
