06-03-2015 01:00 PM - edited 03-17-2019 03:13 AM
Hello Every One,
Here is my issue please.
Any suggestions please.Thank you!
06-03-2015 01:22 PM
Looks like a telco issue, however it is too difficult to conclude it that way.
Could you please explain the topology to us?
06-03-2015 01:39 PM
Please explain the detail call flow example
IP Phone -- SCCP - CUCM -- H323 -- Gateway -- PRI --- PSTN
What is the complete number been sent.
JB
06-05-2015 01:08 PM
Did few more tests and Here is the call flow..
Location A
Other deskphone users from same location call below number and call passes through and outsiders calling below deskphone call passes through.
1514XXXXXXX-->Cfwd--->8514XXXXXX(Cell Phone)
Location B
User calling above deskphone number 1514XXXXXXX which will be "OnNet" call and call do not pass through.
Telco message you need to dial 1 or 0 for long distance call
We use Device and line permissions.
06-05-2015 05:55 PM
Hi shamkumar,
let met try to explain in my own words:
1) the problem is only in Location B (Location A is OK)
2) if Phone B (a Phone in Location B) has a CFAll to (for example):
a) 81514XXXXXXX configured, then:
a.1) if an Outsider Caller calls Phone B then the call completes.
a.2) if a Local Caller calls Phone B then you receive a message indicating a problem
b) 8514XXXXXXX configured then:
b.1) if an Outsider Caller calls Phone B then you receive a message indicating a problem.
b.2) if a Local Caller calls Phone B then the call completes
am I correct?
If my understanding is correct ... it looks like the following (for example):
An Outside Caller (ANI 1408XXXXXXX) calls Phone B (DN 1514XXXXXXX) that has a CFAll to 8514YYYYYYY ... Telco receives a call from 1408XXXXXXX to a local number (514YYYYYYY), as soon as it's not possible (a local number makes local calls, not a Long Distance Number), the call didn't complete.
Check if you are passing the Phone B DN to the Telco ... not the Outsider Caller DN. Ok?
Note: if you send the GW's log ('debug voip ccapi inout') then we can have a better understand about this
Hope this helps.
06-03-2015 10:28 PM
Hi shamkumar,
it's a Telco message ... '81' indicates a long distance call and '8' a local call.
In other words, you should add a '81' for all long distances calls and only '8' for all local calls for the Telco to correct complete your call.
Hope this helps.
