Call from CME to other PABX
nguyendd
Hi all,
My proplem is, when I call from my CME to an other PABX, the call was established successful and can hear the AA. But when I dial the extension, the call drop. Call flow as below:
1. Call to an other PABX number
2. Hear the AA voice
3. Dial extension number
4. Call drop
Below is my telephony-service configuration:
telephony-service
 sdspfarm units 10
 sdspfarm tag 1 confer2
 conference hardware
 max-ephones 58
 max-dn 300
 ip source-address 192.168.31.1 port 2000
 load 7942 SCCP42.9-3-1SR4-1S
 time-zone 41
 time-format 24
 max-conferences 22 gain -6
 call-forward pattern .T
 transfer-system full-consult
 transfer-pattern .T
 create cnf-files version-stamp May 07 2014 13:45:00
Hi Nguyen,
You've not specified the dtmf-relay to be used for these dial-peers. It looks like you are using h323 as the protocol to send the call to the PABX? Is that right?
If so, add the 'dtmf-relay  h245-alphanumeric' command to the dial-peers that are pointing to the PABX and try the call again.
7 Replies 7
Suresh Hudda
did you apply dtmf relay to the dial peer which is pointing to pbx ?
Suresh
I think it is a pots dial-peer from cme to pabx
Hi Suresh,
Thanks for your reply. Here is my dial-peer configure:
dial-peer voice 1 voip
 destination-pattern 4..
 session target ipv4:192.168.20.3
dial-peer voice 2 voip
 destination-pattern 9T
dial-peer voice 3 voip
 destination-pattern 111
dial-peer voice 40 voip
 destination-pattern 8T
Nguyen
Hi Nguyen,
It's worked, thank you very much, Sreekanth
Glad to know that! Thanks for updating.
And dial-peer of gateway 192.168.20.3
dial-peer voice 20 voip
 destination-pattern 2..
 session target ipv4:192.168.21.2
dial-peer voice 30 voip
 destination-pattern 3..
dial-peer voice 10 voip
 destination-pattern 1..
dial-peer voice 2 pots
 service aa
 port 0/1/1
Nguyen
