Call from External to AA
ricardorojas123
I have a trunk SIP connected to CCME, this trunk SIP is used to process incoming and outgoing calls. The incoming and outgoing calls works fine. The problem is the AutoAttendant and VoiceMail. Internally the extensions can hear the Auto Attendant and when a extension does not answer, the prompt of the voice mail is heard, but from the external call to AutoAttendant, the prompt is not heard, the same for the voice mail, the prompts are not heard.
Topology:
(Router_2800) --->SIP trunk ---->  (ISP)
This is the configuration:
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
dial-peer voice 1900 voip
description *InternalExtensions*
destination-pattern 555....
voice-class codec 1
session protocol sipv2
session target ipv4:172.17.30.1
dtmf-relay sip-notify
dial-peer voice 1901 voip
description ***CUE_Voicemail***
destination-pattern 1901
session target ipv4:172.17.30.2
codec g711ulaw
no vad
dial-peer voice 1902 voip
description *AutoAttendant*
destination-pattern 1902
voice-class codec 1
no vad
dial-peer voice 2000 voip
tone ringback alert-no-PI
description *External Calls*
destination-pattern 9143T
voice-class codec 1
session target ipv4:172.19.25.2
dtmf-relay rtp-nte
19 Replies 19
Marwan ALshawi
try to add the follwoing dial peer and see if it helps or not
dial-peer voice 90 voip
incoming called-number .
codec g711ulaw
good luck
if helpful Rate
I change the settings to dial-peer called dial-peer voice 1902 voip (dial peer to the AA), codec and incoming number, but dont work .
Another suggestion?
I noticed that the calls between the internal IP Cisco Phone to the Auto Attendant in the Cisco Unity Express are established using the g711ulaw codec, and the codec used between the external call to internal IP Cisco Phone is g711alaw . Is possible change the codec g711ulaw to g711alaw in he connection from the CUCM to CUE ?
Example, actual codec used:
ITSP  --> g711alaw  --> (CUCME) ---> g711ulaw ---> Auto Attendant (CUE)
Cisco IP Phone registered in the CUCME ---> g711ulaw ----> Auto Attendant (CUE)
you can by using incoming voip dialpeer same concept of the above one
lets say from cucm ip phnes dial cue with number 1000
in the voice gateway where cue reside:
dial-peer voice 99 voip
incoming called-number 100
codec g711ulaw
and you already have outgoing dial-peer with the command destination pattern to send the the call to the right destination
good luck
Hello ricardorajas123
Did you manage to solve this problem?
I have exactly the same problem as you had, and I'm pulling my hair on this one...
I hope you have an answer.
regards,
Jon
CUE does not support g711alaw codec.
Only g711ulaw is the supported codec.
So hardcode dialpeers pointed to CUE
(VM/AA etc.) with g711ulaw and no vad.
For the other leg (incoming) if the codec is
other than g711ulaw, you'd need to configure
transcoding.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmetrnsc.html
DK
Hi Dilip.
I configured the transcode a bit earlier today, and now the call is forwarded to VM/AA. But the problem now is that I do NOT hear the VM/AA prompt...just silence. With debug I can see that the call is active.
Jon
Hmm..I think u mean, you do *NOT* hear CUE prompts. The first thing you want to check is the RTP legs and if
xcoding is getting invoked. Following will help:
sh voip rtp connect
sh sccp connection
FYI, for ulaw<->alaw conversion you'd need universal xcoders:
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t15/it_unitr.html
Another thing to note is for xcoding to be invoked, you need to hardcode codecs on both inbound and outbound
dialpeers rather than using a voice class-codec command.
Are u comfortable with capturing debugs and sharing your config in case we need to troubleshoot it further?
DK
jon.aril.antonsen wrote:
Hi Dilip.
I configured the transcode a bit earlier today, and now the call is forwarded to VM/AA. But the problem now is that I do hear the VM/AA prompt...just silence. With debug I can see that the call is active.
Jon
Hi.
I will look into this right away.
It will be no problem sharing debugs and configs. This is just in a lab enviroment...so no secrets here :-)
When you say both in an put dial peers I rekin you refer to the VM/AA dial-peers?
I will post the result shortly :-)
Jon.
Hi again.
This is what i got from the show commands. The commands issued while having active call to the AA PSTN number.
UC520#sh voip rtp conn
VoIP RTP active connections :
No. CallId     dstCallId  LocalRTP RmtRTP LocalIP            RemoteIP
1   1337       1338       19512    22430  MY_OUTSIDE_IP     SIP_GW_IP
2   1338       1337       16384    20844  10.1.10.2          10.1.10.1
3   1339       1340       19304    2000   10.1.10.2          10.1.1.1
4   1341       1340       17082    2000   10.1.10.2          10.1.1.1
Found 4 active RTP connections
UC520#sh sccp conn
sess_id    conn_id      stype mode     codec   sport rport ripaddr
7          7            xcode sendrecv g711u   17722 2000  10.1.1.1
7          8            xcode sendrecv g711a   17490 2000  10.1.1.1
Total number of active session(s) 1, and connection(s) 2
I'm also quite sure the codecs are configured correctly. But still just silence.
Jon.
As you need to get an incoming SIP call routed as a SIP call to the CUE, also check to see if you have allowed this
i.e
voice sevice voip
allow connections sip to sip
I would also recommend configuring the CUE dial-peer as a b2bua.
If you are switching on the sip-sip feature, please make sure you don't inadventantly make your router into an open SIP gateway.
Adam
Hi Adam.
Cheers for the input.
All the settings you mentioned are set, but no luck :-(
Jon
dksingh
Yep, xcoder is getting invoked it seems but those IP addr.
don't ring a bell in the absence of config.
If u can, please go ahead and capture following debugs for
one call from SIP trunk/PSTN to CUE/AA:
deb ccsip mess
deb ccsip err
deb voip ccapi inout
Note: Please capture debugs in a buffer ; configure following
         before enabling/capturing debugs:
         conf t
         service time deb date msec
         service sequence
          no logg con
          logg mon warn
          logg buffer 5000000 debug
          no logging rate
Issue clear log just before making the test call and once done
issue term len 0 and capture sh log output in a text file.
Please include calling/called num, call flow and config (sh run)
Pl. capture sh voip rtp connect and sh sccp connect for the same
call as well.
DK
