Call id is always 1 or 0
safak.budak
                   Hi all,
I am using CUBE as SIP gateway. When i run "show call active voice brief" command, all the calls have the same call id 1 or 0. So it is hard to track calls at the gateway. Is it normal? Does anybody know the reason of that?
10 Replies 10
Please, add an example of the output of the command.
Regards.
Hi.
If you are using sip-ua to connect to a TSP, you can use show sip-ua calls brief
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
How can i see the dial-peers used for the call if i use "show sip-ua calls brief"?
Safak
You can see used SP with show voice call status.
Sample output:
0    : 69572 09:34:05.177 Turkey Mon Dec 9 2013.1 +5300 pid:1 Answer XXXX active
dur 00:00:03 tx:169/27040 rx:166/26560
IP :28838 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long duration call duration:n/a timestamp:n/a
0    : 69573 09:34:05.187 Turkey Mon Dec 9 2013.1 +5290 pid:106 Originate XXXXXXXXXXX active
dur 00:00:03 tx:167/26720 rx:170/27200
IP :18450 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
Here is another sample output from another sip gateway(this is not CUBE, it is AS5400)
0    : 360645 12:32:18.042 Turkey Mon Dec 9 2013.1 +5800 pid:1 Answer XXXX active
dur 00:00:17 tx:1/160 rx:870/139200
IP :30262 SRTP: off rtt:0ms pl:14470/0ms lost:0/0/0 delay:55/55/65ms g711ulaw TextRelay: off
0    : 360646 12:32:18.094 Turkey Mon Dec 9 2013.1 +5750 pid:106 Originate XXXXXXXXXXX active
dur 00:00:17 tx:871/146328 rx:259/41122
Tele 7/1:D (360646) [7/1.1] tx:17430/3560/0ms g711ulaw noise:-66 acom:45  i/0:-66/-42 dBm
I've some AS5400 but I see call ID without problem. Do you have the same IOS version on boot AS and CUBE?
I have IOS version of 15.1(4)M6 on AS5400 and 15.1(4)M4 on CUBE(3925)
Incoming calls are generated from a CUCM?
https://supportforums.cisco.com/thread/2126193
Yes, calls are generated from CUCM. When we generate the call from PSTN we get a usual call ID for the call legs. Additionallay, not only null, i also see 1 as the call id when the call is generated from CUCM:
From 3925:
1    : 77849 13:55:21.747 Turkey Tue Dec 10 2013.1 +14450 pid:1 Answer XXXX active
dur 00:00:20 tx:1045/167200 rx:1043/166880
IP :22684 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
1    : 77850 13:55:21.747 Turkey Tue Dec 10 2013.2 +14450 pid:106 Originate XXXXXXXXXXX active
dur 00:00:20 tx:1043/166880 rx:1045/167200
IP :17522 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
From AS5400:
1    : 378233 14:03:39.836 Turkey Tue Dec 10 2013.1 +8060 pid:5 Answer XXXX active
dur 00:00:19 tx:1/160 rx:982/157120
IP 10.45.100.64:17584 SRTP: off rtt:0ms pl:13840/0ms lost:0/0/0 delay:55/55/65ms g711ulaw TextRelay: off
1    : 378234 14:03:39.884 Turkey Tue Dec 10 2013.1 +8010 pid:106 Originate XXXXXXXXXXX active
dur 00:00:19 tx:983/165144 rx:291/46242
Tele 7/3:D (378234) [7/3.2] tx:19680/4200/0ms g711ulaw noise:-68 acom:45  i/0:-67/-32 dBm
I couldn't find out what causes this.
