CALL INFORMATIONAL ERROR
john_ufrj
Hello!
I'm using one 2921 with C2900-UNIVERSALK9-M Version 15.1(2)T1 IOS connected with NEC centrals.
I can do internal calls normally but when do one external call the destination receive the call and the source keep calling.
Looking the debug voice vtsp all one error occurs.
/-1/xxxxxxxxxxxx/VTSP:():-1:-1:-1/vtsp_call_setup_request: CALL_ERROR_INFORMATIONAL; B-Channel Is Not Set Call Id=30
B-channel is for ISDN right? But i'm not using it =(
Help me! =)
thanks
yahsiel2004
Level 7
Level 7
Would you be able to post your config and or explain in more detail how the call routing is configured.
Yosh
HTH Regards, Yosh
Config:
version 15.1
hostname name
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 520000
enable secret 5 $1$mTKB$JZaD9GkPQEoT5Im8Bx6f0.
aaa new-model
aaa session-id common
memory-size iomem 5
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
ip domain name
voice-card 0
codec complexity medium
dspfarm
dsp services dspfarm
voice call convert-discpi-to-prog
voice call carrier capacity active
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
signaling forward unconditional
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  ds0-num
  subscription maximum accept 50
  registrar server
  early-offer forced
  support-path-header
voice class codec 2
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 gsmamr-nb
voice class codec 1
voice cause-code
voice register global
mode cme
source-address ------ip-----
max-dn 50
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
controller E1 0/0/0
clock source internal
line-termination 75-ohm
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
  country brazil use-defaults
  metering
  category 2
  answer-signal group-b 1
description NEC-PBX
controller E1 0/0/1
framing NO-CRC4
ds0-group 1 timeslots 1-15 type r2-digital r2-compelled ani
ds0-group 2 timeslots 17-31 type r2-digital r2-compelled ani
cas-custom 1
  country brazil
  metering
  category 2
cas-custom 2
  country brazil
  metering
  category 2
ip ssh time-out 60
ip ssh authentication-retries 2
interface GigabitEthernet0/0
ip address
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 146.164.1.196
interface GigabitEthernet0/1
ip address
duplex auto
speed auto
interface GigabitEthernet0/2
ip address
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route
logging esm config
control-plane
voice-port 0/0/0:0
cptone BR
voice-port 0/0/1:1
cptone BR
voice-port 0/0/1:2
cptone BR
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 24
associate application SCCP
shutdown
dial-peer voice 1 pots
description exit-NEC-PBX
destination-pattern 0%
port 0/0/0:0
forward-digits all
dial-peer voice 2 pots
description extensions
destination-pattern [1-9]...
port 0/0/0:0
forward-digits 4
dial-peer voice 1001 voip
description CUCM-to-PBX
destination-pattern .%
session target ipv4:
voice-class codec 2
dial-peer voice 1002 voip
destination-pattern 995.
voice-class codec 2
dial-peer voice 3 pots
destination-pattern 4%
port 0/0/1:1
no dial-peer outbound status-check pots
sip-ua
gatekeeper
zone local  enable-intrazone
gw-type-prefix 4...
no shutdown
scheduler allocate 20000 1000
end
Debug voice vtsp all
Feb 27 16:07:33.458: //-1/xxxxxxxxxxxx/VTSP:(0/0/0:0):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x30D3F950
Feb 27 16:07:33.458: //-1/xxxxxxxxxxxx/VTSP:(0/0/0:0):-1:-1:-1/vtsp_insert_cdb:
Feb 27 16:07:33.458: //-1/xxxxxxxxxxxx/VTSP:(0/0/0:0):-1:-1:-1/vtsp_process_event:
   [state:INVALID STATE MACHINE, event:E_CC_SETUP_REQ]
Feb 27 16:07:33.458: //47/E70053000000/VTSP:(0/0/0:0):-1:-1:-1/vtsp_og_call_req:
   Echo Cancel=TRUE, Gain Control=0
   Auto Gain Control=FALSE, Dual Tone Detect Mask=0x0, Seq Tone Detect=FALSE
Feb 27 16:07:33.458: //47/E70053000000/VTSP:(0/0/0:0):-1:-1:-1/vtsp_do_call_setup_req:
Feb 27 16:07:33.458: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_opened_cb:
Feb 27 16:07:33.458: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
   [state:S_SETUP_REQ_PEND, event:E_VTSP_DSM_OPEN_SUCCESS]
Feb 27 16:07:33.458: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/act_setup_req_pend_succ:
Feb 27 16:07:33.458: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_request_call:
   Mode=0, Peer=1
Feb 27 16:07:33.458: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_create_call_active_on_setup_req:
   Target Carrier ID=
Feb 27 16:07:33.462: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_create_call_active_on_setup_req:
   Source Carrier ID=
Feb 27 16:07:33.462: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_request_call:
   Progress Indication=0, Info Trans Capability=0
   Calling Number=1012, TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed
   Called Number=099565575, TON=Unknown, NPI=Unknown
Feb 27 16:07:33.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
   [state:S_SETUP_REQUEST, event:E_TSP_PROCEEDING]
Feb 27 16:07:33.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/act_setup_pend_proceeding:
Feb 27 16:07:33.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_timer:
   Timer Start Time=2298190, Timer Value=25000(ms)
   Peer=1, Progress Indication=0, Return Code=2
   [state:S_NULL, event:E_TSP_R2_DIAL]
Feb 27 16:07:33.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/act_setup_req_pend_defer:
   Event=19
   Event=19
Feb 27 16:07:33.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_opened_cb:
   [state:S_NULL, event:E_VTSP_DSM_OPEN_SUCCESS]
Feb 27 16:07:33.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/act_setup_req_wait_pend_success:
   Event=75
Feb 27 16:07:33.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=2298190
Feb 27 16:07:33.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/act_setup_r2_pend_dial:
   Digits=#, Tone Mode=1
Feb 27 16:07:33.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_r2_dial:
Feb 27 16:07:33.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:33.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:33.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
   Digits To Dial=0
Feb 27 16:07:34.038: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:
Feb 27 16:07:34.038: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
   Begin Digit=1, Mode=CC_TONE_R2_MF_FORWARD_MODE
Feb 27 16:07:34.038: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:exit@484
Feb 27 16:07:34.038: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
   [state:S_R2_DIALING, event:E_VTSP_DIGIT_BEGIN]
Feb 27 16:07:34.038: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit_up:
   [state:S_R2_DIALING, event:E_TSP_R2_DIAL]
Feb 27 16:07:34.038: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:34.038: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:34.038: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:34.126: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:
Feb 27 16:07:34.126: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
   End Digit=1, Mode=CC_TONE_R2_MF_FORWARD_MODE
Feb 27 16:07:34.126: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:exit@606
Feb 27 16:07:34.126: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
   [state:S_R2_DIALING, event:E_VTSP_DIGIT_END]
Feb 27 16:07:34.126: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit:
Feb 27 16:07:34.126: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:34.126: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:34.126: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=9
Feb 27 16:07:34.278: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:
Feb 27 16:07:34.278: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:34.278: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:exit@484
Feb 27 16:07:34.278: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:34.278: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit_up:
Feb 27 16:07:34.278: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:34.278: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:34.278: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:34.370: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:
Feb 27 16:07:34.370: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:34.370: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:exit@606
Feb 27 16:07:34.370: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:34.370: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit:
Feb 27 16:07:34.370: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:34.370: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:34.370: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=9
Feb 27 16:07:34.686: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:
Feb 27 16:07:34.686: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
   Begin Digit=9, Mode=CC_TONE_R2_MF_FORWARD_MODE
Feb 27 16:07:34.686: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:exit@484
Feb 27 16:07:34.686: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:34.686: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit_up:
Feb 27 16:07:34.686: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:34.686: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:34.686: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:34.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:
Feb 27 16:07:34.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
   End Digit=9, Mode=CC_TONE_R2_MF_FORWARD_MODE
Feb 27 16:07:34.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:exit@606
Feb 27 16:07:34.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:34.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit:
Feb 27 16:07:34.826: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:34.830: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:34.830: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=9
Feb 27 16:07:34.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:
Feb 27 16:07:34.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:34.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:exit@484
Feb 27 16:07:34.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:34.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit_up:
Feb 27 16:07:34.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:34.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:34.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:35.006: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:
Feb 27 16:07:35.006: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:35.006: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:exit@606
Feb 27 16:07:35.006: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:35.006: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit:
Feb 27 16:07:35.006: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:35.006: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:35.006: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=9
Feb 27 16:07:35.146: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:
Feb 27 16:07:35.146: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:35.146: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:exit@484
Feb 27 16:07:35.146: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:35.146: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit_up:
Feb 27 16:07:35.146: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:35.146: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:35.146: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:35.226: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:
Feb 27 16:07:35.226: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:35.226: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:exit@606
Feb 27 16:07:35.226: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:35.226: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit:
Feb 27 16:07:35.226: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:35.226: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:35.226: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=5
Feb 27 16:07:35.318: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:
Feb 27 16:07:35.318: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:35.318: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:exit@484
Feb 27 16:07:35.318: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:35.318: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit_up:
Feb 27 16:07:35.318: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:35.318: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:35.318: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:35.398: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:
Feb 27 16:07:35.398: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:35.398: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:exit@606
Feb 27 16:07:35.398: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:35.398: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit:
Feb 27 16:07:35.398: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:35.398: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:35.398: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=6
Feb 27 16:07:35.486: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:
Feb 27 16:07:35.486: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:35.486: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:exit@484
Feb 27 16:07:35.486: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:35.486: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit_up:
Feb 27 16:07:35.486: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:35.486: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:35.486: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:35.578: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:
Feb 27 16:07:35.578: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:35.578: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:exit@606
Feb 27 16:07:35.578: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:35.578: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit:
Feb 27 16:07:35.578: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:35.578: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:35.578: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=5
Feb 27 16:07:35.670: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:
Feb 27 16:07:35.670: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:35.670: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:exit@484
Feb 27 16:07:35.670: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:35.670: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit_up:
Feb 27 16:07:35.670: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:35.670: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:35.670: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:35.750: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:
Feb 27 16:07:35.750: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:35.750: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:exit@606
Feb 27 16:07:35.750: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:35.750: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit:
Feb 27 16:07:35.750: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:35.750: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:35.750: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=5
Feb 27 16:07:35.838: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:
Feb 27 16:07:35.838: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:35.838: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:exit@484
Feb 27 16:07:35.838: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:35.838: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit_up:
Feb 27 16:07:35.838: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:35.838: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:35.838: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:35.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:
Feb 27 16:07:35.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:35.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:exit@606
Feb 27 16:07:35.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:35.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit:
Feb 27 16:07:35.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:35.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:35.918: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=7
Feb 27 16:07:36.010: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:
Feb 27 16:07:36.010: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:36.010: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:exit@484
Feb 27 16:07:36.010: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:36.010: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit_up:
Feb 27 16:07:36.010: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:36.010: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:36.010: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:36.090: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:
Feb 27 16:07:36.090: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:36.090: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:exit@606
Feb 27 16:07:36.090: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:36.090: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit:
Feb 27 16:07:36.090: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:36.090: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:36.090: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=5
Feb 27 16:07:40.810: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:
Feb 27 16:07:40.810: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
   Begin Digit=3, Mode=CC_TONE_R2_MF_FORWARD_MODE
Feb 27 16:07:40.810: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:exit@484
Feb 27 16:07:40.810: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:40.810: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit_up:
Feb 27 16:07:40.810: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:40.810: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:40.810: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:40.890: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:
Feb 27 16:07:40.890: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
   End Digit=3, Mode=CC_TONE_R2_MF_FORWARD_MODE
Feb 27 16:07:40.890: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:exit@606
Feb 27 16:07:40.890: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:40.890: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit:
Feb 27 16:07:40.890: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:40.890: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:40.890: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=2
Feb 27 16:07:40.978: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:
Feb 27 16:07:40.978: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:40.978: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_begin_cb:exit@484
Feb 27 16:07:40.978: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:40.978: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit_up:
Feb 27 16:07:40.978: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dial:
Feb 27 16:07:40.978: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dial_nopush:
Feb 27 16:07:40.978: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_do_dial:
   Digits To Dial=#
Feb 27 16:07:41.058: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:
Feb 27 16:07:41.058: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_report_cas_digit:
Feb 27 16:07:41.058: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_digit_end_cb:exit@606
Feb 27 16:07:41.058: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
Feb 27 16:07:41.058: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_digit:
   [state:S_R2_DIALING, event:E_TSP_R2_END_DIAL]
Feb 27 16:07:41.178: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_dial_done_cb:
Feb 27 16:07:41.178: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
   [state:S_R2_DIALING, event:E_VTSP_DSM_DIALING_COMPLETE]
Feb 27 16:07:41.178: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/dc_dialing_done:
   [state:S_R2_DIALING_COMP, event:E_TSP_R2_END_DIAL]
Feb 27 16:07:41.178: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/ds_end_dial:
Feb 27 16:07:41.178: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_digit_pop:
   Digit Reporting=FALSE
Feb 27 16:07:41.178: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/act_setup_pend_dial_comp:
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_process_event:
   [state:S_SETUP_REQ_PROC, event:E_TSP_ALERT]
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/act_setup_pend_alert:
   Progress Indication=8, Signal Indication=1
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_ring_noan_timer_start:
   Timer Start Time=2298944, No Answer Timer Value=180000(ms)
   Ringback Indication=FALSE, Ring Timeout=180(s)
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_bridge_check_cb:
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_bridge_check_cb:exit@1468
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_bridge_status_cb:
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_save_fax_config:
   Fax Relay=ENABLED
   Primary Fax Protocol=T38_FAX_RELAY, Fallback Fax Protocol=NONE_FAX_RELAY
   Fax Relay CM Suppression :=ENABLED, Fax Relay ANS Suppression :=DISABLED
   Fax Parameters Set By=Dialpeer, Peer=1001
   Fax Version:=0, LS Red=0, HS Red=0
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_set_fax_feat_param:
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_save_tty_config:
   Save TTY configuration
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_set_tty_feat_param:
   Set TTY feat parameters
   [state:S_SETUP_REQ_PROC, event:E_CC_DO_CAPS_IND]
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_peer_event_cb:
   Event=E_DSM_CC_CAPS_IND
   [state:S_SETUP_REQ_PROC, event:E_CC_CAPS_IND]
   Event=E_DSM_CC_CAPS_ACK
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_feature_notify_cb:
   Feature ID=0, Feature Status=1
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_reactivate_ringback:
Feb 27 16:07:41.358: //47/E70053000000/VTSP:(0/0/0:0):-1:1:1/vtsp_dsm_reactivate_ringback:exit@1259
someone?
John,
I have a few questions below:
1 - Have you ever been able to make calls externally successfully before? If so, what has changed?
2 - Have calls been able to reach an internal phone successfully before? If so, what has changed?
3 - What dialpeer are you trying to match when making an external call?
4 - What dialpeer are you trying to match for incoming external calls?
5 - E1 Controller 0/0/0 doesn't have "framing NO-CRC4" was that negated for a reason?
Brazil
controller E1 0/0
 framing NO-CRC4
 cas-custom 0
  country brazil
  category 2
Note: Some Telefonica circuits require metering to be enabled. If needed,           add the metering command under           cas-custom.
There are a few caveats on E1 R2 which we can look into.
E1 R2 Caveats
The following is a list of software caveats related to E1 R2. In order       to follow these bug ID links and see detailed bug information, you must be a       registered user and you must be logged in.
Cisco Bug ID Description
CSCed55231 MRP does not clear R2 call cleanly
CSCed22834 ICS7700 does not recognize inbound BLOCKING state
CSCec77853 One way audio with SIP and E1 R2
CSCec64185 E1 R2: Bad implementation of A-2 signal for                     Argentina
CSCec58903 E1 R2: AS does not detect BLOCKING state
CSCea55028 voice call stuck if call setup time takes more than                     15s
CSCea17341 Calls fail with answer signal group A and no DID                     configured
CSCdz69604 5400 E1 R2 is not sending answer signal group A
CSCeb36413 E1 R2 call fails on 5400 and 5850
CSCdy36274 E1 R2 hung call when redial to same destination
CSCea64554 Call stuck on 3600 when hairpining from E1 R2 to                     ISDN
CSCea61403 Unprotected buginf in R2 calls
CSCed44156 E1 R2 needs configurable DNIS timeout for 2600
CSCdy22974 Spurious memory access at tsp_voice_call_check on                     OGW
CSCdx66463 R2 voice port locks up in R2_Q421_IC_CLR_BWD state
CSCea81777 Hairpin call get disconnect from E1 R2 to CAS                     E&M
CSCeb52314 AS5850 chooses a DS0-group not defined on the POTS                     dial-peer
CSCdz66927 Voice-ports Hung and Digits not being pulsed out
CSCeb65150 E1 R2 Needs configurable DNIS timeout for 7200                     series
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a008024903b.shtml
Yosh
HTH Regards, Yosh
