call intercept using attendant console
nkariyawasam
is it possible for operator to intercept and established call using either attandant console under UCM 6.1 ?
If not what is the product we need to use ?
if you want to barge into a call or intercept a call you're looking for UCCX.
at most you can barge in with CUCM but that is not compatible with AC since shared lines are not supported
javalenc
if this helps, please rate
java
smalkeric
Level 6
Level 6
The call distribution logic is very simple - linear only. And the call can be answered only from a Work station to which the call is presented.
javalenc
java
