09-25-2008 10:39 AM - edited 03-15-2019 01:32 PM
I have programmed a hunt list, line group and hunt pilot. When I dial the hunt pilot number I get a busy signal. I tried resetting the hunt list. Can anyone offer any assistance? Do I need to restart call manager service?
Dianna
09-25-2008 11:51 AM
you shouldn't, try resetting all the elements and try again.
java
if this helps, please rate
09-25-2008 11:58 AM
What elements are you referring to?
09-25-2008 11:54 AM
Another thing to check is the CSS to make sure it's hitting the pilot.
09-26-2008 05:24 AM
Hi Dianna,
I think Java was referring to doing a reset on the Hunt Pilot, Hunt List and Line Group. You can also ensure that on the Hunt Pilot config page that the "Route this Pattern" checkbox has been checked.
Hope this helps!
Rob
09-26-2008 06:15 AM
Rob,
Thanks for the response.I reset the hunt list and updated the others and continue to get a busy signal when I dial the pilot number. Also route this pattern checkbox was checked. Any other suggestions?
Dianna
09-26-2008 08:24 AM
Hi Dianna,
Hmmmmmm...
Did you check the Partition and Calling Search Space?
Rob
