Call Manager 9 CDR error message
Helmi Muzammil
Hi All,
When I opened the CDR and Analysis Reporting, there was a warning message popup that said there is a suspected error billing table.
Then, When I generate the CDR error, i found this log :
 31110: which means that dateTimeConnect in a CDR record is not a positive integer
My question is What does it means? and how to fix it?
Manish Gogna
Hi Helmi,
As per the following link:
https://supportforums.cisco.com/document/55821/troubleshooting-cdr
"In the above example, the error codes are:
  and
  31148: which means that destDeviceName in a CDR record is NULL
The above error codes imply that the call was not connected (i.e. it did not enter a connected state) but a CDR record was nevertheless created for it. Since the call was not connected, it's not a 'billable' call. Hence, the corresponding record is entered into tbl_billing_error (as opposed to tbl_billing_data). This behavior is frequently observed on systems where the CallManager service parameter: 'CDR Log Calls with Zero Duration Flag' is enabled. If this service parameter is entered, a CDR record will be generated for calls that were never connected or were connected for less than a second. Most common scenarios that cause such CDR records:
- When a user goes off-hook and then on-hook without completing a call.
- When a user completes a blind transfer (the consultation call does not connect prior to transfer completion).
- MWI On/Off calls.
If you observe a large number of entries in tbl_billing_error due to any of above scenarios, you can disable the CallManager service parameter: 'CDR Log Calls with Zero Duration Flag'.
Manish
- Do rate helpful posts -
Manish Gogna
Hi Helmi,
  and
- MWI On/Off calls.
Manish
