03-13-2016 07:17 AM - edited 03-17-2019 06:13 AM
Dear All Experts
i am using call manager 9.x and using enhanced and enhanced plus licenses, now for some purpose we have used CUWL license for 3 , 4 users whihc was running in demo mode, now demo period is going to expired and i have deleted all that devices/users who were using CUWL license, and update license usage detail from CM and ELM too. but after deleting and checking all thoroughly sysmtem is showing usage of 1 cuwl licnese, but when i opened that it showed nothing in it like no one is using that license, but CM is showing 1 infront of CUwl which is not allowing system to get ot from Demo period to permanent.
attached are the screenshots please help
Solved! Go to Solution.
03-14-2016 07:56 AM
I was checking the bug. Is this related to your issue ?
03-13-2016 07:27 AM
Did u click on Update Usage Details after u removed the devices from CUWL user?
regds,
aman
03-13-2016 01:02 PM
Yes Aman
I did it also and from ELM also but its still showing 1 in CUWl...
03-13-2016 09:46 PM
Are u able to see users under UCL Enhanced/ TP?
If yes, there could be a bug which I could not find.
Lastly, can u try restarting from ELM ---Administration --Restart in non-office hours
regds,
aman
03-14-2016 05:27 AM
Thanks aman soi for your help,Problem resolved after deleting Jabber users form CM and its a bug i think because jabber user were only using one device that should be in Enhanced license
03-14-2016 06:07 AM
thanks for update. You are correct.
What exactly u did?
What I could suspect :There could be issue with mapping of Owner Id under Device Phone.
can u share the snapshot from system ---licensing?
What is exact version of CUCM and share show version active?
regds,
aman
03-14-2016 07:56 AM
03-14-2016 01:38 PM
System version: 9.1.2.10000-28
exactly when i add jabber for android devices they used to get CUWL license all the time but not for jabber for iphone.
