call-manager-fallback command error
balitewiczp
Level 2
Level 2
trying to add the command    max-dn 200 dual-line to a srst config,    I get the following error kicked back
HOST301(config-cm-fallback)#max-dn 200 dual-line
ERROR: could not add peer
*****cm_fallback_create_dns fails for max dn 200 line-mode 1
anyone see this b4?
Rob Huffman
Hi Pete,
Hope all is well
Here is a good clip from Jo and TAC regarding this issue.
Have a look;
After this our 3825 Gateways with 256 MB Mem refused the command max-dn. It still worked, but only for very low numbers. (up to 23). So I opend a TAC Case and the anser was
The system is now
telling you that there is not enough memory to add dial-peers into the
system.  Note that the threshold is 80% for 256M or less, 85% for
256-512M and 90% for > 512M of processor memory. The system will not let
you add ephone-dn's (dial-peers) when it's available processor memory is
below that threshold.
Below is two relevant URL that discuss this:
How to determine the maximum number of dial-peers that can be configured
on a router
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K34857008
When calculating the memory requirements for the number of dial-peers
required you can use the following:
    Router>show memory summary
                Head       Total (b)   Used (b)  Free (b)   Lowest (b)
Largest (b)
    Processor   60AB4ED0   5550384     2082996   3467388    3464996
3454608
    I/O         40000000   16777216    1937280   14839936   14839936
14838908
Total = the total amount of memory available after the system image
loads and builds its data structures.
We also saw in the following document that 512 MB of memory are recommended.
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/requirements/guide/srs71spc.html
Bye
Jo
https://supportforums.cisco.com/message/1174670#1174670
Cheers!
Rob
Rob Huffman
Hi Pete,
Hope all is well
Have a look;
The system is now
on a router
Largest (b)
3454608
14838908
Bye
Jo
Cheers!
Rob
Perfect.  Spot on.  router only has 256K in it.
Thanks for the quick reply
