call-manager-fallback max-dn
I am trying to understand correctly the max-dn function of the Basic SRST mode for IOS 15.5-3-M5
Actually, we would like to have 40 different ephones (max-ephones 40) with 2 DN each registered to the GW (so 80 DN), but each DN would need the possibility to receive more than 2 simultaneous calls.
I am not sure if:
max-dn 80 octo-line
or
max-dn 40 number octo-line
or
max-dn 40 dual-line number octo-line
or
max-dn 80 octo-line number octo-line
would be the appropriate configuration ?
Thank you for your help
That's right. It's basically the same thing that I highlighted. The "number" is basically being described as a parameter. So effectively per the doc, they mean -
max-dn <number> dual-line|octo-line
which translates to in the config as -
max-dn 80 dual-line
or,
max-dn 80 octo-line
7 Replies 7
R0g22
You can just have "max-dn 80" to accommodate the extensions. Dual-line/Octo-line refers to the number of virtual channels/EFXS ports i.e. 2 and 8 respectively which governs how many calls can each DN accommodate. So dual DN's can have 2 simultaneous calls while Octo can have 8.
Thank you for the fast reply.
So, if we want any of the 80 DN to receive up to 8 calls each, it would be:
max-dn 80 octo-line
right ?
If so, then what is the "number" parameter for within' that command ?
Thank you
That's right. What "number" parameter are you referring to ?
I can't seem to find the document where I read that. The page I looked for a few days ago is now 404 not found, and all other documentations kind of differ. It was a command parameter, similar to "preference". Anyways, it works now, and I can see how the channels are reserved using show voice port summary and show call-manager-fallback ephone-dn
Thank you and have a good day
Let me know in case you can find the command in here -
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/SCCP_and_SIP_SRST_Admin_Guide.html
SRST Admin Guide has everything related to traditional SRST and ESRST.
Ok, I found it back, and it is in the admin guide:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/SCCP_and_SIP_SRST_Admin_Guide/srst_setting_up_using_sccp.html
Search for: number octo-line
But I think I misunderstood it. I guess it only shows that you can set up either directory numbers with dual-line, or octo-line, or both.
So, it could be:
max-dn 10 dual-line
max-dn 10 octo-line
or
max-dn 10 dual-line 10 octo-line
It's just that "number" term that is confusing, it's described as a "parameter" in the purpose section.
max-dn 80 dual-line
or,
max-dn 80 octo-line
