Call Manager & Voice Gateway Compatibility
Ryan Gunn
I am checking on CUCM version and Voice Gateway IOS version compatability.  I have checked the following ling, but it is showing only 1 supported version.  Does anyone have a more comprehesive list of the supported IOS versions for CUCM versions 8.0 and 8.5?
http://tools.cisco.com/ITDIT/vtgsca/VTGServlethttp://tools.cisco.com/ITDIT/vtgsca/VTGServlet
Ryan
Rob Huffman
Hi Ryan,
In addition to the good notes from Kevin (+5 )
The Gateway IOS version is really "independant" of the CUCM version.
In most cases the versioning of the two is is based more on a minimum
supported feature contained in the IOS. For example, an  ISR 2821 might
be running 12.4(20)T with CUCM 7.x and the migration to CUCM 8.5 does not
mean that the IOS needs to be upgraded unless you were looking for some sort
of new feature support or to mitigate a bug or bugs.
Keep in mind that most of the docs like the one you linked only show the
"tested" version.
I quite like this doc
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
5 Replies 5
Kevin Monteiro
Level 7
Level 7
Hey Ryan,
Here you go:
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/unified/communications/system/versions/IPTMtrix.html#wp1016708
Hope this helps!!!!!
Kindly rate this post accordingly.
Kevin
Rob Huffman
Hi Ryan,
"tested" version.
Cheers!
Rob
Ryan Gunn
Thank you guys!  Great info here.
Both get a +5 Thanks for the quick responses
Steven DiStefano
One small thing to just keep an eye out for, is if you are going to use an existing 28xx in an upgrade, where the customer intends to add, 69xx SIP phones at a remote Branch office, then you will need to look at SRST 8.0 minimum, which comes in IOS 15 (not 12), and then you need to make sure that router has enough Flash/Dram to support the new IOS release, not to mention if it still has Smartnet to entitle you to even download the IOS for it.
So while I agree and learn from this thread, beware of the gotchas.
Rob Huffman
Hi Ryan,
You are always welcome my friend
Steve....thanks for adding the SRST "gotchas". +5 for this
great addition buddy! Nice to see you posting over here
Cheers!
Rob
