IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5591 Views
  • 14 replies
I currently run a 2901 in a remote location running through the CM in our corporate office. They since have requested running a virtual rightfax machine through that gateway. I was hoping I can have the rightfax server go straight through the GW with...
mbarlow by Level 1
  • 787 Views
  • 4 replies
Resolved! Debug for a loop
                   Hi, in my company we have Avaya an cisco coexisting, I noticed, taht sometomes we hace calling loops, so id like to make a debug in the gateway between cisco and avaya to find out wich phone call is creating the loop in order to co...
Hi All , Just a small query for personal knoweldge's sake, me and my respective colleague had a brief technical chat on intercluster stuff in UC enviroment and he brought about the concept of things being done through the port 8002 .            Kindl...
Hello EveryoneI need some suggestions, I have two CISCO 2811 (2 x Fastethernet Interface) routers with 3550 (POE) Switch & I am planning for CCNA/CCNP voice.What are the requirements to setup voice lab with mentioned routers?Thanks in AdvanceSabby
Sabby0115 by Level 1
  • 545 Views
  • 2 replies
Hello Friend,I have a problem on CallerID of PSTN lines on my CME. I,ve enabled the caller ID under the voice-ports but the phones doesn't show the caller ID. I tested caller ID with nomal phones. It seems that the CO sends the caller ID before the f...
Hi,Is there a way to see the dial-plan rules defined in a COP file? I thought CUCM creates a log during dial-plan installation and that log contains the rules that make up the country specific dial-plan. I couldn't locate it in the installation logs....
