Call Park BLF - HELP!
TheRealBTU
CME 12.0  //  All 8851 phones
Having a devil of a time here getting Call Park BLF's to work.  I have two BLF speed dial line appearances setup system wide for two call park slots on 8851 phones.  I can not seem to get the BLF's to illuminate at all when a call is parked on either slot.  Is this possible on 8851 phones running CME 12.0?
There is no indication that a call is parked on either slot without the lamp illuminating.
Thanks!
6 Replies 6
TheRealBTU
Update;  below are pictures of the phone screen and also the dn config for each park slot.  Are we missing something here?  The white circle "P" never changes on the phone and the BLF never illuminates when a call is parked - on any phone system wide.
Maybe you could share the BLF configuration as well as that would make it easier for anyone to help you out.
Response Signature
Hi Roger, configuration is attached with identifying info removed.  Is this what you're looking for?  Thanks!
Not sure if this still applies, but according to this document it is not supported on SIP phones.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmepres.html#concept_14401702A6F54FAA9044027F369C66D2
Response Signature
Just got it to work!  Just needed to add "allow watch" to the ephone-dn's for the two Call Park slots.  BLF works perfectly now.  Thanks for your help!
Great ’:-)’
Response Signature
