Call Park Length - Unified CM 7.1
rwamstutz
Hello. A quick question regarding call park in v.7.1. How can I extend the length of time that a call can be parked? on v4 we had 3 minutes approx, however right now on 7.1 we are only at 1 minute. Thanks for your help.
Rob Huffman
Hey Rob,
I was just looking at this recently :)
Call Park Reversion
Call Park Reversion Timer - Default specifies 60 seconds. This parameter determines the time that a call remains parked. Set this timer for each server in a cluster that has the Cisco CallManager service and call park configured. When this timer expires, the parked call returns to the device that parked the call.
Note: To set the timers, choose System > Service Parameters and update the Call Park Display Timer and the Call Park Reversion Timer fields in the Clusterwide Parameters (Feature-General) pane.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00806b7ecb.html
Hope this helps!
Rob
Thanks for your quick response...do you know, will this reset the phones?
Hi Rob,
You are most welcome my friend! This will not reset the IP Phones.
Cheers!
Rob
