03-15-2012 08:30 AM - edited 03-16-2019 10:08 AM
We are in the process of moving a new office to our centralized call manager that currently uses the Call Park feature. They want this set up for 4 lines with 4 parks. I added a a Call Park configuration under Call Park in CUCM with a mask of 795[0-5] to allow for the numbers and added Park to a phone for testing. However when I park a call it goes to 7950 and when I try to pull it down to a different phone to retrieve the call from call park I get a fast busy.
I have the call park set up to our internal partition so all of our phones can pull the calls that ar parked. What am I missing here?
Do I need to configure a route pattern for the call Park numbers?
If anyone here at the forum can assist with this it would be great.
Thank you.
Rgds,
Vicky
03-15-2012 08:54 AM
No, that is all you need. Ensure the partition is in fact available on the device's CSS.
Can you retrive the call back from the phone that parked it?
Chris
03-15-2012 08:58 AM
Hi Chris,
Yes I get the call bouncing back to the phone where the park was initiated. Do I need to set u specific extensions for Call Park?
03-15-2012 09:01 AM
Hi Vicky,
Is it possible that the IP phones you are testing with are registered to
different servers in the cluster?
If you have 3 servers in the cluster there should be 3 park number
ranges shown via Feature>Call Park and each range should be associated to 1 of the 3
Communication manager servers. So it might look something like this
400x - CM_1
401x - CM_2
402x - CM_3
# Field | # Description |
# Call Park Number/Range | # Enter the call park extension number. You can enter literal digits or the wildcard character X (the system allows one or two Xs). For example, enter 5555 to define a single call park extension number of 5555 or enter 55XX to define a range of call park extension numbers from 5500 to 5599. #Note You can create a maximum of 100 call park numbers with one call park range definition. Make sure that the call park numbers are unique. #Note You cannot overlap call park numbers between Cisco Unified Communications Manager servers. Ensure that each Cisco Unified Communications Manager server has its own number range. |
# Description | # Provide a brief description of this call park number. |
# Partition | # If you want to use a partition to restrict access to the call park numbers, choose the desired partition from the drop-down list box. If you do not want to restrict access to the call park numbers, choose See Searching for a Partition in the Cisco Unified Communications Manager Administration Guide for instructions on finding a partition when there are a large number of them configured. #Note Make sure that the combination of call park extension number and partition is unique within the Cisco Unified Communications Manager cluster. |
# Cisco Unified Communications Manager | # Using the drop-down list box, choose the Cisco Unified Communications Manager to which these call park numbers apply. #Note You can create a maximum of 100 call park numbers with one call park range definition. Make sure that the call park numbers are unique. #Note You cannot overlap call park numbers between Cisco Unified Communications Manager servers. Ensure that each Cisco Unified Communications Manager server has its own number range. |
"Configure a unique call park number or define a range of call park extension numbers
for each Cisco Unified Communications Manager in the cluster."
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fscallpk.html#wp1150638
Cheers!
Rob
