Call redirect
S Sadiq
Hi ,
I have one issue I wanted to  direct the 858 xxx xxxx (receptionist when customer chooses 0 for operator) to the hunt group 888 xxx xxxx?
how can I do that ?
If a number doesn't exist in CUCM, as an exact match, or as a wildcard, you cannot do anything with it, you just need to create the translation pattern.
Else, explain the exact call flow you want to have.
java
if this helps, please rate
6 Replies 6
hsood
Is 858 XXX XXXX a DN on CUCM?
If it is, you can set the CFA on the Line page to 888 XXX XXXX.
Else, you can create a Translation pattern for 858 XXX XXXX and set called party transform mask to 888 XXX XXXX.
Hitesh
I tried to add the line CFA on line of 888 xxx xxxx but the problem is this number doesn't exist on cucm
the other number 858 xxx xxxx s exist a DN on cucm.
I though of creating Translation pattern of 858 xxx xxxx but how can i do that if the other number doesn't exist on cucm
can you assist me in this
java
Thanks !
I had some other issue phone got rebooted
When I collected the event logs I got stationerror code reason=4 and 3.
Not sure which all service I have check for phone reboot issue so I checked event related and got the logs
can you assist me with this
Aseem Anand
Hi Shaikh,
Is the call being redirected to CUCM from Unity connection auto attendant when user presses 0 or the IP phones users call 0 to reach reception, like a speed dial?
(a). If the call is being transferred from CUC then make sure you have the correct hunt pilot number set in the caller input entry corresponding to 0 for the call handler.
(b). If the users simply dial 0 to reach receptionist then you can configure a translation pattern on CUCM which translates 0 to a hunt pilot number.
Aseem
how can i verify the call is being redirected to cucm from unity auto attendant when user presses 0
