Call to the PSTN, the sound does not rise. DSP control queue full, msg 73
Dany Fortin
On Cisco ISR4321/K9,  IOS Software Version 15.5(2)S2.  With PVDM subslot 0/4, DESCR: "PVDM4-32 Voice DSP Module" and NIM subslot 0/1", DESCR: "NIM-2BRI-NT/TE Voice Analog Module"
interface BRI0/1/0:0
 no ip address
 isdn switch-type basic-net3
 isdn twait-disable
 isdn point-to-point-setup
 isdn incoming-voice voice
 isdn static-tei 0
 trunk-group PSTN-MRI
interface BRI0/1/1:0
 no ip address
 isdn twait-disable
 isdn static-tei 0
dspfarm profile 1 conference
 description Ne pas oublier d'enlever les Codecs G729
 codec g711alaw
 codec g711ulaw
 maximum sessions 8
 associate application SCCP
Sh log
Apr 14 10:51:55.380: %ISDN-6-CONNECT: Interface BRI0/1/1:1 is now connected to 54901 Name. Corpo
Apr 14 10:52:10.364: %ISDN-6-DISCONNECT: Interface BRI0/1/1:1  disconnected from 932699999 , call lasted 14 seconds
Apr 14 10:52:22.139: %DSMP-3-DSP_TIMEOUT: DSP timeout on DSP 1/1:1: event 0x6, DSMP timed out, while waiting for statistics from the DSP. DSMP State = S_DSMP_COLLECTING_STATS
Apr 14 10:53:14.904: Dprint DSP(1/1) CH(0) SEQ(36)control queue full: chan 1, msg 73
Debug isdn q931
Apr 14 12:10:52.564: ISDN BR0/1/0:0 Q931: RX <- SETUP pd = 8  callref = 0x6F
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x81
                Preferred, B1
        Progress Ind i = 0x8483 - Origination address is non-ISDN
        Calling Party Number i = 0x0183, '0014189999999'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xA1, '934769999'
                Plan:ISDN, Type:National
Apr 14 12:10:52.571: ISDN BR0/1/0:0 Q931: TX -> CALL_PROC pd = 8  callref = 0xEF
        Channel ID i = 0x89
                Exclusive, B1
Apr 14 12:10:52.715: ISDN BR0/1/0:0 Q931: TX -> ALERTING pd = 8  callref = 0xEF
Apr 14 12:10:52.742: Dprint DSP(1/1) CH(0) SEQ(46)control queue full: chan 1, msg 73
Apr 14 12:11:04.841: ISDN BR0/1/0:0 Q931: TX -> CONNECT pd = 8  callref = 0xEF
        Channel ID i = 0x89
                Exclusive, B1
Apr 14 12:11:04.909: ISDN BR0/1/0:0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x6F
Apr 14 12:11:04.910: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 54901 Name. Corpo
Apr 14 12:11:13.934: ISDN BR0/1/0:0 Q931: RX <- DISCONNECT pd = 8  callref = 0x6F
        Cause i = 0x8A90 - Normal call clearing
Apr 14 12:11:13.934: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1  disconnected from 0014189999999 , call lasted 9 seconds
Apr 14 12:11:13.934: ISDN BR0/1/0:0 Q931: TX -> RELEASE pd = 8  callref = 0xEF
        Cause i = 0x8090 - Normal call clearing
Apr 14 12:11:14.004: ISDN BR0/1/0:0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x6F
8 Replies 8
saif musa
Level 4
Level 4
Your dsp card is either gone for sleep or shuts down, if you keep collecting those logs did the pvdm4 card recovers and return back to work or it just shutdown for ever ? What happens after restarting the hole device ?
After restarting the router the communication is back to normal.
is there any voice quality issues occur ( on the period of 14 sec ) befor this times out shows up ? Just like ( one way voice, echo , noise channel ).
Once the call is established between the caller and the callee, no sound from one side or the other.
Dany,
Could upload the result from ( show version ) please....
Cisco IOS XE Software, Version 03.15.02.S - Standard Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(2)S2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 16-Oct-15 18:00 by mcpre
barrt05t uptime is 4 days, 23 hours, 56 minutes
Uptime for this control processor is 4 days, 23 hours, 57 minutes
System returned to ROM by reload at 14:20:12 med Thu Apr 14 2016
System restarted at 14:23:10 med Thu Apr 14 2016
System image file is "bootflash:isr4300-universalk9.03.15.02.S.155-2.S2-std.SPA.bin"
Last reload reason: Reload Command
Technology Package License Information:
Technology    Technology-package           Technology-package
                      Current          Type               Next reboot
appx             None               None                 None
uc                 uck9                Permanent        uck9
security         securityk9       Permanent        securityk9
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4321/K9 (1RU) processor with 1665776K/6147K bytes of memory.
Processor board ID FLM1924W0LI
2 Gigabit Ethernet interfaces
2 ISDN Basic Rate interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3223551K bytes of flash memory at bootflash:.
There is compatibility, cant figure out if there is hardware issue and cant figure out if there is software bug. now Im waiver,  we have to wait someone from Cisco to tell us how to troubleshoot this. OR, if you have another Cisco router with pvdm4 card, i recommend to swap dsp cards between them and see if the fault moves with it.
inform me please for any update about that
We believe the bug CSCuu40514 corresponds to our problem.
I'll change for IOS : isr4300-universalk9.03.17.01.S.156-1.S1-std.SPA.bin
To be continued...
