04-14-2016 11:13 AM - edited 03-17-2019 06:34 AM
On Cisco ISR4321/K9, IOS Software Version 15.5(2)S2. With PVDM subslot 0/4, DESCR: "PVDM4-32 Voice DSP Module" and NIM subslot 0/1", DESCR: "NIM-2BRI-NT/TE Voice Analog Module"
interface BRI0/1/0:0
no ip address
isdn switch-type basic-net3
isdn twait-disable
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
trunk-group PSTN-MRI
interface BRI0/1/1:0
no ip address
isdn twait-disable
isdn static-tei 0
dspfarm profile 1 conference
description Ne pas oublier d'enlever les Codecs G729
codec g711alaw
codec g711ulaw
maximum sessions 8
associate application SCCP
Sh log
Apr 14 10:51:55.380: %ISDN-6-CONNECT: Interface BRI0/1/1:1 is now connected to 54901 Name. Corpo
Apr 14 10:52:10.364: %ISDN-6-DISCONNECT: Interface BRI0/1/1:1 disconnected from 932699999 , call lasted 14 seconds
Apr 14 10:52:22.139: %DSMP-3-DSP_TIMEOUT: DSP timeout on DSP 1/1:1: event 0x6, DSMP timed out, while waiting for statistics from the DSP. DSMP State = S_DSMP_COLLECTING_STATS
Apr 14 10:53:14.904: Dprint DSP(1/1) CH(0) SEQ(36)control queue full: chan 1, msg 73
Debug isdn q931
Apr 14 12:10:52.564: ISDN BR0/1/0:0 Q931: RX <- SETUP pd = 8 callref = 0x6F
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Progress Ind i = 0x8483 - Origination address is non-ISDN
Calling Party Number i = 0x0183, '0014189999999'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xA1, '934769999'
Plan:ISDN, Type:National
Apr 14 12:10:52.571: ISDN BR0/1/0:0 Q931: TX -> CALL_PROC pd = 8 callref = 0xEF
Channel ID i = 0x89
Exclusive, B1
Apr 14 12:10:52.715: ISDN BR0/1/0:0 Q931: TX -> ALERTING pd = 8 callref = 0xEF
Apr 14 12:10:52.742: Dprint DSP(1/1) CH(0) SEQ(46)control queue full: chan 1, msg 73
Apr 14 12:11:04.841: ISDN BR0/1/0:0 Q931: TX -> CONNECT pd = 8 callref = 0xEF
Channel ID i = 0x89
Exclusive, B1
Apr 14 12:11:04.909: ISDN BR0/1/0:0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x6F
Apr 14 12:11:04.910: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 54901 Name. Corpo
Apr 14 12:11:13.934: ISDN BR0/1/0:0 Q931: RX <- DISCONNECT pd = 8 callref = 0x6F
Cause i = 0x8A90 - Normal call clearing
Apr 14 12:11:13.934: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1 disconnected from 0014189999999 , call lasted 9 seconds
Apr 14 12:11:13.934: ISDN BR0/1/0:0 Q931: TX -> RELEASE pd = 8 callref = 0xEF
Cause i = 0x8090 - Normal call clearing
Apr 14 12:11:14.004: ISDN BR0/1/0:0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x6F
04-14-2016 12:13 PM
Your dsp card is either gone for sleep or shuts down, if you keep collecting those logs did the pvdm4 card recovers and return back to work or it just shutdown for ever ? What happens after restarting the hole device ?
04-14-2016 12:16 PM
After restarting the router the communication is back to normal.
04-15-2016 04:08 AM
is there any voice quality issues occur ( on the period of 14 sec ) befor this times out shows up ? Just like ( one way voice, echo , noise channel ).
04-15-2016 04:53 AM
Once the call is established between the caller and the callee, no sound from one side or the other.
04-16-2016 10:51 PM
Dany,
Could upload the result from ( show version ) please....
04-19-2016 05:26 AM
Cisco IOS XE Software, Version 03.15.02.S - Standard Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(2)S2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 16-Oct-15 18:00 by mcpre
barrt05t uptime is 4 days, 23 hours, 56 minutes
Uptime for this control processor is 4 days, 23 hours, 57 minutes
System returned to ROM by reload at 14:20:12 med Thu Apr 14 2016
System restarted at 14:23:10 med Thu Apr 14 2016
System image file is "bootflash:isr4300-universalk9.03.15.02.S.155-2.S2-std.SPA.bin"
Last reload reason: Reload Command
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appx None None None
uc uck9 Permanent uck9
security securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4321/K9 (1RU) processor with 1665776K/6147K bytes of memory.
Processor board ID FLM1924W0LI
2 Gigabit Ethernet interfaces
2 ISDN Basic Rate interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3223551K bytes of flash memory at bootflash:.
04-19-2016 11:02 PM
There is compatibility, cant figure out if there is hardware issue and cant figure out if there is software bug. now Im waiver, we have to wait someone from Cisco to tell us how to troubleshoot this. OR, if you have another Cisco router with pvdm4 card, i recommend to swap dsp cards between them and see if the fault moves with it.
inform me please for any update about that
05-04-2016 08:30 AM
We believe the bug CSCuu40514 corresponds to our problem.
I'll change for IOS : isr4300-universalk9.03.17.01.S.156-1.S1-std.SPA.bin
To be continued...
