Call Transfer issue
BigK
Level 5
Level 5
I have this scenario and could not figure it out. When a call arrives to receptionist, she answers the call, and when she transfers the call to the intended user/Ext, the call just keep ringing, it does not get forwarded to the user's voicemail.
This is intermittent cross each location.
Voice Mail Profile is assigned voice mail
Forward Busy Internal  yes
Forward Busy External yes
Forward No Answer Internal yes
Forward No Answer External yes
Forward Unregistered Internal yes
Forward Unregistered External yes
what else I can check?
Karim
ItalkNetworks
Hi Karim,
++ Please check what is configured for 'No Answer Ring Duration (seconds)' in the line configuration on CUCM.
++ Does the issue occur for internal call as well? so , if I call from one IP-Phone to another IP-Phone(which transfers the call), does the issue occur in that scenario as well?
Please rate if, helpful.
HTH,
Akansha Sharma
Dennis Mink
what is the behavior when you call the extension directly, rather then transferring to it from reception?  is it the same?  does call forward all to voice mail work?
Please remember to rate useful posts, by clicking on the stars below.
@ItalkNetworks
@Dennis Mink
  • There is nothing configured under Answer Ring Duration
  • This is only happens on external calls
  • Calling the extension directly will go to voicemail if no one picks up
Thanks for your time.
Karim
