06-10-2011 12:15 AM - edited 03-16-2019 05:23 AM
How do we set up called party number type in isdn setup message using h323 gateway? Do we do it using Route List in the CCM or using the translation rule on the gateway itself?
Vinay
06-10-2011 01:46 AM
Hey Vinay ,
since this is H323 GW , prefer to do it using Voice translation rule to set the type of the called /calling , you can do this per Dial-peer level if you have profissional dial-peer config for each call type (local, LD,Int) .
or else you can configure it on the route pattern level , if you have route pattern for each call type
my opinion is to do it on your GW using Translation rule ,
Ash
06-10-2011 02:00 AM
Hi Vinay
I suggest you to apply the voice translation rule on the H.323 gateway to change the Called party number in isdn messages. This works perfect in all call scenarios. Here's an example..
In this example, if a number starts with "4" and the type is "national", the rule adds "90" as a prefix. If the type is "international", the rule adds "900" as the prefix.
voice translation-rule 7 rule 1 /^4/ /904/ type national national rule 2 /^4/ /9004/ type international international
router#test voice translation-rule 7 493456567 type national Matched with rule 1 Original number: 493456567 Translated number: 90493456567 Original number type: national Translated number type: national Original number plan: none Translated number plan: none router#test voice translation-rule 7 493456567 type international Matched with rule 2 Original number: 493456567 Translated number: 900493456567 Original number type: international Translated number type: international Original number plan: none Translated number plan: none
Pl rate if info is useful ! Thanks.
