Caller ID in VoiceMail
drenich
CUE 3.2.2 on NME. CME 4.2 on 3825 12.4.11XW9.
Incoming call answered by operator. Transfer external caller to internal extension. Extension does not answer and gets sent to voicemail. External caller leaves message. Header on message says that it came from the operator not the external number.
Any ideas on where to start looking?
7 Replies 7
drenich
From a debug of voice ccapi. Why is the calling number 621 instead of the outside caller number?
Nov 3 18:50:00.225: //5324/0D32C8B0BB5E/CCAPI/ccCallSetupRequest:
Calling Number=621(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=700(TON=Unknown, NPI=Unknown),
Redirect Number=225, Display Info=Incoming Call
Account Number=, Final Destination Flag=FALSE,
Guid=0D367239-A90F-11DD-BB62-E9CD57A1838B, Outgoing Dial-peer=240
Nov 3 18:50:00.225: //5324/0D32C8B0BB5E/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=621
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=700
cisco-desttype=0
cisco-destplan=0
cisco-rdie=73
cisco-rdn=225
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=15 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
drenich
Config from the CME.
telephony-service
load 7960-7940 P00308000500
load 7906 SCCP11.8-2-2SR2S
load 7911 SCCP11.8-2-2SR2S
max-ephones 185
max-dn 300
ip source-address 10.36.10.1 port 2000
max-redirect 10
calling-number initiator
service dnis overlay
service dnis dir-lookup
timeouts interdigit 4
system message Cowley County Mental Health
url services http:///voiceview/common/login.do
url authentication http:///voiceview/authentication/authenticate.do
time-zone 8
voicemail 700
max-conferences 12 gain -6
hunt-group logout HLog
multicast moh 239.10.16.16 port 2000
web admin system name vadci secret 5 $1$cHT/$qTAiUHgmWCmH8J1qrBxbZ.
web admin customer name admin secret 5 $1$/BGO$XaNul3dfQzs3PCOLf10a31
dn-webedit
transfer-system full-consult dss
transfer-pattern 7..
transfer-pattern 1..
night-service code *123
night-service day Sun 08:30 08:00
night-service day Mon 20:00 08:00
night-service day Tue 20:00 08:00
night-service day Wed 18:00 08:00
night-service day Thu 18:00 08:00
night-service day Fri 17:00 09:00
night-service day Sat 09:00 08:30
night-service date Jan 1 00:00 23:59
night-service date Dec 25 00:00 23:59
night-service date Sep 1 00:00 23:59
fac standard
create cnf-files version-stamp 7960 Oct 30 2008 21:09:07
grundle1322
I am having the same issue with a client. Did you ever get this issue resolved?
Hello All,
In the CLI of the CUE module, enter the command "voicemail callerid"
Hope that helped, if so please rate.
Mine was the following command on the CME.
Telephony-service
Took that command out and then it worked the way that they wanted.
I have verified that CUE is configured for 'voicemail callerid', and I have attempted with both 'calling-number initiator' enabled and disabled and I still am getting "extension xxx" as the sender when listening to messages instead of the proper caller-id. I am using CUE 3.2.1. Does anyone have any other suggestions?
This is my CME config. I did a no calling-number initiator to get rid of it. I am running IOS 12.4.20T1
telephony-service
load 7906 SCCP11.8-3-3S
load 7911 SCCP11.8-3-3S
max-ephones 110
max-dn 300
max-redirect 10
time-zone 8
voicemail 700
web admin system name XXX secret 5 XXX
web admin customer name XXX secret 5 XXX
dn-webedit
night-service date Nov 11 00:00 23:59
night-service date Nov 27 00:00 23:59
night-service date Nov 28 00:00 23:59
night-service date Dec 24 00:00 23:59
fac standard
create cnf-files version-stamp 7960 Nov 06 2008 10:23:11
