08-10-2016 12:38 PM - edited 03-17-2019 07:47 AM
I am experiencing a issue:
Office users configures "call forward all " to their cell phone on their desk phone, when a outside caller calls in their desk phone, the cell phones doesn't show the correct outside caller's phone number. The number showing on the cell phone, seems it is generated from the phone system.
The office users and phone system are located in Germany, CUCM8 + H323 voice gateway. I ran the debug on the voice gateway, it showed the gateway was sending outside caller's phone number to the PSTN.
Question:
. Any solution for this? Any parameters or configuration on CUCM/VGW could reflect the correct caller ID when call forwarding kicks in?
Your information and help is appreciated.
Master001
08-10-2016 12:57 PM
The problem is likely a function of your carrier overwriting the caller ID. Some carriers will only allow outbound caller ID to be one of the DIDs on the circuit. Check with your carrier to see if they are overwriting the number.
Brandon
08-10-2016 01:23 PM
Telephony in Germany is a little bit different from other countries. So try to check with carrier if it sent the caller id or if that are a service that need to be hired separately.
Best regards,
Daniel
08-10-2016 12:57 PM
User you h323 gateway check what you have selected under "Call Routing Information - Outbound Calls"
JB
08-11-2016 09:20 AM
Thanks all for your input.
One thing I forgot to mention, is CLIP no screening feature just activated recently. However, before and after this change, the issue is the same.
The debug below shows the calling party number type is "Unknown". The carrier said all calling party number type should be " National".
Question:
Could this calling party number type " Unknown" be the issue?
What I could make changes to update this calling party number type as "National" in call forward scenario?
( Attached the h323 vgw debug)
Thanks again.
Master001
Aug 10 13:56:02.498: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0BEC
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98384
Exclusive, Channel 4
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '0509XXXXXX' ! number omitted
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '0160XXXXXXXX' ! This is forwarded number - mobile phone omitted
Aug 10 13:56:02.510: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8BEB
Aug 10 13:56:02.534: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8BEC
08-11-2016 09:29 AM
below is how you can change type and plan on GW
http://www.voicecerts.com/2011/04/voice-translation-rules-examples.html
JB
08-11-2016 09:31 AM
Another helpful link
http://www.ucguerrilla.com/2012/09/taming-dial-peers-for-ccie-v-lab.html
JB
