ā07-11-2013 02:21 PM - edited ā03-16-2019 06:20 PM
Jul 11 21:02:34.407: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x007D
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98386
Exclusive, Channel 6
Facility i = 0x91A12702026EE902010F301E0201010A0101A116A014A1120A0101120D39313132343431333238303233
Calling Party Number i = 0x1183, '9101206712000'
Plan:ISDN, Type:International
Called Party Number i = 0x81, '2023'
Plan:ISDN, Type:Unknown
Jul 11 21:02:34.415: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x807D
Jul 11 21:02:34.415: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x807D
Facility i = 0x9FAA06800100820100A1080201010201018400
Progress Ind i = 0x8088 - In-band info or appropriate now available
Jul 11 21:02:38.195: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x007D
Cause i = 0x8090 - Normal call clearing
Jul 11 21:02:38.215: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x807D
Jul 11 21:02:38.279: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x007D
Jul 11 21:02:38.783: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x007E
Sending Complete
Standard = CCITT
Channel ID i = 0xA98387
Exclusive, Channel 7
Facility i = 0x91A11902026FCA02010F30100201010A0103A108A006800435383030
Calling Party Number i = 0x0083, '7459'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '2112'
High Layer Compat i = 0x9181
Jul 11 21:02:38.787: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x807E
Cause i = 0x8081 - Unallocated/unassigned number Calling Party Number i = 0x1183, '9101206712000'
The caller id shown "9101206712000" is incorrect. it should be either "911206712000" or "01206712000". how can i change it?
Kindly help.
Solved! Go to Solution.
ā07-11-2013 04:27 PM
This is what the telco is sending you, you can have them change it, or if you want you can add a translation rule to the GW to strip or prefix digits.
HTH,
Chris
HTH,
Chris
