Showing results forĀ
Search instead forĀ
Did you mean:Ā
Caller ID with Call Manager 7 and MGCP controlled GW with FXO port
aklyuka30
I saw many topics discussing problem of Caller ID  on FXO port with MGCP cotrolled gateway.
It was NOT supported  by call manager 6
Is it supported on Call Manager 7 ? ( i recently upgraded to CCM 7 )
Or Caller ID sitll is not important feauture for cisco ?
I have 20 remote officess with 2911 gw controlled by MGCP and i would liek to avoid if possible switching them to H323
Thanks in advance for any informative response
It could be nice to hear any answer from cisco TAC .
grundle1322
Caller ID on MGCP gateways with FXO ports was added to the 8.0 release.  See the link for the new features added in version 8.0.  I do not have the version notes here but you will also need to make sure the IOS on your routers can handle the new feature.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_0_1/delta/nc-801-cm.html
Hope this document clarifies the situation, essentially CLID is supported for MGCP FXO in 12.4(20)T or later and CUCM 8.0:-
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
Hope this helps
Allan.
