Caller Input trouble
aaron.banks11
I have a call handler set up in which I press # to go back to a main menu from a submenu.  When I do that, the # takes me to some announcement and then I can leave a message.  I cannot for the life of me find where this # is taking me.
Here is the output from remote port status monitor:
02:03:48, Playing greeting for Call Handler:  Main
02:03:48, No DTMF received
02:03:48, Event is [NULL]
02:03:48, PHTransfer
02:03:48, State - PHTransfer.cde!LoadInfo
02:03:48, Answer Phone if needed
02:03:48, Event is [FalseEvent]
02:03:48, State - PHTransfer.cde!CheckPlayTransferIntro
02:03:48, Event is [TrueEvent]
02:03:48, State - PHTransfer.cde!PlayTransferIntro
02:03:49, Event is [NULL]
02:03:50, State - PHTransfer.cde!XferCall
02:03:51, Event is [TransferFailed]
02:03:51, State - PHTransfer.cde!LeaveMsg
02:03:51, Event is [NULL]
02:03:51, PHGreeting
02:03:51, State - PHGreeting.cde!PlayGreeting
02:03:51, Call answered if needed
02:03:51, Playing Greeting: Standard
02:03:51, Playing greeting for Subscriber:  reception
02:03:53, Event is [HangupEvent]
02:03:53, State - PHGreeting.cde!DoHangup
02:03:53, Idle
Any suggestions are welcome.  There are dozens of auto attendants and I have tried to listen to every standard, holiday and off hours greeting but can't even find the same greeting!
Andrew West
Level 4
Level 4
Is the greeting a custom one or system default?
Every time I run into a similar issue I prefer to go through with ATM and even more with the new version which allows you to generate Visios.
It is a custom greeting and I have been using ATM to do the programming.  I'll check on the new version.  The one I am currently using does not appear to have that capability.
Are the visio diagrams stored somewhere? I was able to get the updated version but no diagrams ever show up.
