caller name from our system
zrunner626
Couple weeks ago, we had reports that calls outbound to external clients were showing up as "Private" instead of our company name. We have not made any configuration changes however the carrier swears we are overriding the CNAM info with information we are sending out. Can anyone give me some ideas where or how to verify this on our system?
Call Manager version 12
ISR3945 gateways, IOS 15.7(3)M4b
H323 PRI
thanks
Jaime Valencia
Start by debugging your GW and see the debugs for those calls, what are you sending in the SETUP message?
If it's the right info, then it's something between your telco and the other end doing that, as that is the last point over which you have any control.
If it's the wrong information, then you'd need to review the call flow in your system to find out where that might be coming from
java
if this helps, please rate
I did run debug voip ccapi inout already...included below to be thorough. I see the correct main number going out and below cc_api_call_setup_ind_common I see the "Calling Name" as blank but in the ccIFCallSetupRequest showing cisco-username=my name. Where does it pull that from and why is it being sent out?
Aug 15 10:53:31.361 CDT: vsacount in free is 4
Aug 15 10:54:07.584 CDT: //-1/007F83E87C04/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=Daniel White
----- ccCallInfo IE subfields -----
cisco-ani=6153831000
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=96153389000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Aug 15 10:54:07.584 CDT: //-1/007F83E87C04/CCAPI/cc_api_call_setup_ind_common:
Interface=0x27C4093C, Call Info(
Calling Number=6153831000,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=96153389000(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=11131, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2039
Aug 15 10:54:07.584 CDT: //-1/007F83E87C04/CCAPI/ccCheckClipClir:
In: Calling Number=6153831000(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=6153831000(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Aug 15 10:54:07.584 CDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 15 10:54:07.584 CDT: :cc_get_feature_vsa malloc success
Aug 15 10:54:07.584 CDT: cc_get_feature_vsa count is 5
Aug 15 10:54:07.584 CDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:703699272,feature_id:2039
Aug 15 10:54:07.584 CDT: //2039/007F83E87C04/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=6153831000(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=96153389000(TON=Unknown, NPI=Unknown))
Aug 15 10:54:07.584 CDT: //2039/007F83E87C04/CCAPI/cc_process_call_setup_ind:
Event=0x283114E8
Aug 15 10:54:07.584 CDT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 96153389000
Aug 15 10:54:07.584 CDT: //2039/007F83E87C04/CCAPI/ccCallSetContext:
Context=0x29F1DFBC
>>>>CCAPI handed cid 2039 with tag 11131 to app "_ManagedAppProcess_Default"
Aug 15 10:54:07.584 CDT: //2039/007F83E87C04/CCAPI/ccCallProceeding:
Aug 15 10:54:07.584 CDT: //2039/007F83E87C04/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=913, Params=0x29F26198, Progress Indication=NULL(0)
Aug 15 10:54:07.584 CDT: //2039/007F83E87C04/CCAPI/ccCheckClipClir:
Destination Pattern=9..........$, Called Number=96153389000, Digit Strip=TRUE
Redirect Number=, Display Info=Daniel White
Account Number=Daniel White, Final Destination Flag=TRUE,
Guid=007F83E8-1F80-51D5-7C04-CA040A010CC9, Outgoing Dial-peer=913
Aug 15 10:54:07.584 CDT: //2039/007F83E87C04/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=96153389000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
Aug 15 10:54:07.584 CDT: //2039/007F83E87C04/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x2984C2EC, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=6153831000,(Calling Name=Daniel White)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=96153389000(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=913, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Aug 15 10:54:07.584 CDT: cc_get_feature_vsa count is 6
Aug 15 10:54:07.584 CDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:703699496,feature_id:2040
Aug 15 10:54:07.584 CDT: //2040/007F83E87C04/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Aug 15 10:54:07.584 CDT: //2040/007F83E87C04/CCAPI/ccCallSetContext:
Context=0x29F2614C
Aug 15 10:54:07.584 CDT: //2039/007F83E87C04/CCAPI/ccSaveDialpeerTag:
Aug 15 10:54:07.586 CDT: ISDN Se1/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 3
Aug 15 10:54:07.586 CDT: ISDN Se1/0:23 Q931: Sending SETUP callref = 0x029E callID = 0x821F switch = primary-5ess interface = User
Aug 15 10:54:07.586 CDT: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x029E
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x2181, '6153831000'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '6153389000'
Aug 15 10:54:07.598 CDT: ISDN Se1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x829E
Aug 15 10:54:07.598 CDT: //2040/007F83E87C04/CCAPI/cc_api_call_proceeding:
Interface=0x2984C2EC, Progress Indication=NULL(0)
Aug 15 10:54:09.264 CDT: ISDN Se1/0:23 Q931: RX <- ALERTING pd = 8 callref = 0x829E
Progress Ind i = 0x8188 - In-band info or appropriate now available
Aug 15 10:54:09.264 CDT: //2040/007F83E87C04/CCAPI/cc_api_call_alert:
Interface=0x2984C2EC, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
Call Entry(Retry Count=0, Responsed=TRUE)
Aug 15 10:54:09.264 CDT: //2039/007F83E87C04/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Aug 15 10:54:09.264 CDT: //2040/007F83E87C04/CCAPI/cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
Aug 15 10:54:09.264 CDT: //2039/007F83E87C04/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x7F7, gcid=0-0-0-0, tag=0x0)
Aug 15 10:54:09.264 CDT: //2040/007F83E87C04/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x7F8, gcid=0-0-0-0, tag=0x0)
Conference Id=0xFFFFFFFF, Call Id1=2039, Call Id2=2040, Tag=0x0
Aug 15 10:54:09.264 CDT: //2039/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 15 10:54:09.264 CDT: cc_api_get_xcode_stream : 4981
Aug 15 10:54:09.264 CDT: //2039/007F83E87C04/CCAPI/cc_api_bridge_done:
Conference Id=0x325, Source Interface=0x27C4093C, Source Call Id=2039,
Destination Call Id=2040, Disposition=0x0, Tag=0x0
Aug 15 10:54:09.264 CDT: //2040/007F83E87C04/CCAPI/cc_api_bridge_done:
Conference Id=0x325, Source Interface=0x2984C2EC, Source Call Id=2040,
Destination Call Id=2039, Disposition=0x0, Tag=0xFFFFFFFF
Aug 15 10:54:09.264 CDT: //2039/007F83E87C04/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0x325, Destination Call Id=2040)
Call Entry(Conference Id=0x325, Destination Call Id=2039)
Aug 15 10:54:09.264 CDT: confID:0x325; callEntry1 callID1:0x7F7, type:1; callEntry2 callID2:0x7F8, type:6
Aug 15 10:54:09.264 CDT: //2040/007F83E87C04/CCAPI/cc_api_caps_ind:
Aug 15 10:54:09.264 CDT: voice_rtp_nse_payload 0, voice_rtp_sse_payload 118 voice_sprt_payload 120
Aug 15 10:54:09.264 CDT: sprt_latency 200, sprt_retries 12
Destination Interface=0x27C4093C, Destination Call Id=2039, Source Call Id=2040,
Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
Aug 15 10:54:09.264 CDT: //2039/007F83E87C04/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=2039
Aug 15 10:54:09.264 CDT: //2039/007F83E87C04/CCAPI/cc_api_get_delay_xport:
CallInfo(delay xport=FALSE)
Aug 15 10:54:09.264 CDT: //2039/007F83E87C04/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x325, Call Id1=2039, Call Id2=2040
Aug 15 10:54:09.278 CDT: //2039/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 15 10:54:09.278 CDT: cc_api_get_xcode_stream : 4981
Aug 15 10:54:09.280 CDT: //2039/007F83E87C04/CCAPI/cc_api_caps_ind:
Aug 15 10:54:09.280 CDT: voice_rtp_nse_payload 100, voice_rtp_sse_payload 118 voice_sprt_payload 120
Aug 15 10:54:09.280 CDT: sprt_latency 200, sprt_retries 12
Destination Interface=0x2984C2EC, Destination Call Id=2040, Source Call Id=2039,
Caps(Codec=0x1, Fax Rate=0x80, Fax Version:=0, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
Aug 15 10:54:09.280 CDT: //2039/007F83E87C04/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_14400(0x80), Fax Version:=0, Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=172)
Aug 15 10:54:09.280 CDT: //2039/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 15 10:54:09.280 CDT: cc_api_get_xcode_stream : 4981
Aug 15 10:54:09.280 CDT: //2040/007F83E87C04/CCAPI/cc_api_caps_ack:
Aug 15 10:54:09.280 CDT: //2040/007F83E87C04/CCAPI/cc_api_voice_mode_event:
Call Id=2040
Call Entry(Context=0x29F2614C)
Aug 15 10:54:20.664 CDT: ISDN Se1/0:23 Q931: RX <- CONNECT pd = 8 callref = 0x829E
Connected Number i = 0x8080, '6153389000'
Aug 15 10:54:20.664 CDT: ISDN Se1/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x029E
Aug 15 10:54:20.664 CDT: //2040/007F83E87C04/CCAPI/cc_api_call_connected:
Interface=0x2984C2EC, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Aug 15 10:54:20.664 CDT: //2039/007F83E87C04/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
Aug 15 10:54:20.664 CDT: //2040/007F83E87C04/CCAPI/cc_api_get_called_ccm_detected:
Call Entry(Connected=TRUE, Responsed=TRUE)
Aug 15 10:54:20.664 CDT: //2039/007F83E87C04/CCAPI/ccCallNotify:
Aug 15 10:54:20.664 CDT: //2039/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 15 10:54:20.664 CDT: cc_api_get_xcode_stream : 4981
Aug 15 10:54:33.325 CDT: //2039/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 15 10:54:33.325 CDT: cc_api_get_xcode_stream : 4981
Aug 15 10:54:33.337 CDT: //2039/007F83E87C04/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x27C4093C, Call Id=2039
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Aug 15 10:54:33.337 CDT: //2039/007F83E87C04/CCAPI/ccConferenceDestroy:
Conference Id=0x325, Tag=0x0
Aug 15 10:54:33.337 CDT: confID:0x325; callEntry1 callID1:0x7F7, type:1; callEntry2 callID2:0x7F8, type:6
Aug 15 10:54:33.337 CDT: //2039/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 15 10:54:33.337 CDT: cc_api_get_xcode_stream : 4981
Aug 15 10:54:33.337 CDT: //2039/007F83E87C04/CCAPI/cc_api_bridge_drop_done:
Aug 15 10:54:33.337 CDT: //2040/007F83E87C04/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=2039, Disposition=0x0, Tag=0x0
Aug 15 10:54:33.337 CDT: //2039/007F83E87C04/CCAPI/cc_generic_bridge_done:
Aug 15 10:54:33.337 CDT: //2039/007F83E87C04/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Aug 15 10:54:33.337 CDT: //2039/007F83E87C04/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
Aug 15 10:54:33.337 CDT: //2040/007F83E87C04/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Aug 15 10:54:33.337 CDT: //2040/007F83E87C04/CCAPI/cc_api_get_transfer_info:
Aug 15 10:54:33.343 CDT: //2039/007F83E87C04/CCAPI/cc_api_get_transfer_info:
Aug 15 10:54:33.343 CDT: //2039/007F83E87C04/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x27C4093C, Tag=0x0, Call Id=2039,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Aug 15 10:54:33.343 CDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 15 10:54:33.343 CDT: :cc_free_feature_vsa freeing 29F19940
Aug 15 10:54:33.343 CDT: vsacount in free is 7
Aug 15 10:54:33.351 CDT: ISDN Se1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x029E
Cause i = 0x8090 - Normal call clearing
Aug 15 10:54:33.357 CDT: ISDN Se1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x829E
Aug 15 10:54:33.357 CDT: ISDN Se1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x029E
Aug 15 10:54:33.359 CDT: //2040/007F83E87C04/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2984C2EC, Tag=0x0, Call Id=2040,
Aug 15 10:54:33.359 CDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 15 10:54:33.359 CDT: :cc_free_feature_vsa freeing 29F19A20
Aug 15 10:54:33.359 CDT: vsacount in free is 6
zrunner626
I have also verfied these settings in Call Manager
Gateway 1: Primary Local Gateway, backup LD
Call Routing Information - Outbound Calls
Calling Party Presentation = Default
Caller ID DN = blank
Display IE Delivery = checked
Gateway2: Primary LD Gateway, backup Local
Display IE Delivery = UNchecked
Route Pattern - 10 digit local call
Calling Party Transformations
Calling Party Transform Mask = Main number
Prefix Digits = blank
Calling Line ID Presentation = Default
Calling Name Presentation = Default
*Same settings for LD Route Pattern
Route Lists
Use Calling Party's External Phone Num Mask = Default
Calling Part Transform Mask = blank
Calling Party Number Type and Plan = Cisco CallManager
