Showing results forĀ
Search instead forĀ
Did you mean:Ā
calling extension is working only when the partition (order) is in the css
Yazen Alaa
Calling extension is working only when the partition (order) is on top  in the css .
Any ideas
Hi.
Probably you have an overlapping routing on different partitions.
Try to use Call routing --> route plan report and see if the destination number is replicated on differen partition.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
yes it is replicated  .
How can we get rid of it
Hi.
If it's an unused extension, you can simply delete it or choose in which partition should be this extension.
You can also search all DN included in that partition and verify if they should be there.
Carlo
