calling from CUCM extension to 3CX extension
How I can call from cucm extension to 3cx extesnion
I have created a trunk to 3CX phone system and created a routepattern with the particular extension.
But I am getting an error message below
SIP/2.0 407 Proxy Authentication Required
Any idea?
Looks like the 3CX system requires authentication. How have you defined the SIP trunk between the two systems, is it in CM directly or do you have a Cube in-between? I doubt that CM has the ability to do authentication on SIP trunks, so you’d need to have a Cube in the path towards the 3CX system to be able to do this.
Response Signature
@Roger Kallberg Thanks for the Reply
It directly from the CM to 3CX system.
Possibly you might be able to change the SIP trunk security profile to one of the secure options, but I never used this for authentication on a trunks so I don't have first hand experience with it. Maybe someone else in the community does?
Response Signature
