calling the trunkline 2400 during SRST is not working and error "Cause i = 0x82E6 - Recovery on timer expiry" found for disconnection
kiervin.munoz
Hi Guys,
We tried to check if the existing SRST is working and when the IP Phones went to SRST, we tried to call the trunk line number 2400 but the call won't get through. Upon checking the debug, we found disconnection cause or information "Cause i = 0x82E6 - Recovery on timer expiry".
Kindly see attached debug and show run of the voice gateway.
Appreciate your inputs regarding this issue.
Suresh Hudda
Put below command in global configure mode and then try once calling.
dial-peer hunt 2
Even if it doesn't work then pls attach 'debug voip ccapi inout'.
Suresh
