CallManager 4.2(3) to 7.0(2) upgrade failes due to DMA error
wkhanagov
I'm receiving the following error when running the DMA tool in CM 4.2(3).
***> DATA PROCESSING TESTS REVEALED AN ISSUE WHICH GENERATED THE FOLLOWING EVENT:
Sorry. Unable to parse and identify error number. Raw Message follows:
07/09/2009 13:23:43.046 installdb| installFull *ERROR* Prior Cancel or Error Processing fixisstandard(DSN=ids_ccm)|
Can anyone shed some light on what this error means?
Thanks!
- William
irisrios
Level 6
Level 6
Check the following:
- From ccmadmin -> system; make sure that all servers are CM servers within the cluster.
- Change the IP address of publisher and subscribers to hostname.
- Verify all the hostnames are in uppercase.
- Verify windows computer name matches with the hostname.
garry.connolly
William
I am having exactly the same issue as you experienced whilst running DMA tool in v4.2(3)
09/21/2009 11:24:34.648 installdb| installFull *ERROR* Prior Cancel or Error Processing fixisstandard(DSN=ids_ccm)|
Did you manage to rectify this issue ?
Garry
We are dealing with this same problem on a DMA upgrade from 4.3 to 7.1.5.
Changeing the server ip addresses to names did not solve the problem.
Did you solve the problem?
Thank you,
Pall
pallo@nyherji.is
