IP Telephony and Phones
Labels
Hi,it is possible to check in the web administration from the cucm 6.x the hardware ? I want to know on which 78xx the server is running and i`m not in the data center where the server is...Other solution on the cli ?regardsJason
Hi.We have a lot of users that share handsets with their extensions assigned to buttons.There as an issue using the Local Directory. If users select the Local Directory first then once they have found the extension they want to call they need to sele...
