10-12-2007 02:05 AM - edited 03-14-2019 11:55 PM
My CCM 6.0 started to display some of the configuration options using the DB Table Field Names instead of original user-friendly format. Has anyone experienced this?
For example:
Inthe region settings;
London TypeBandwidth.BANDWIDTH_1M 384 TypeLossyNetwork.LOSSY_NETWORK_USE_SYSTEM_DEFAULT
Slough TypeBandwidth.BANDWIDTH_729 384 TypeLossyNetwork.LOSSY_NETWORK_USE_SYSTEM_DEFAULT
Warrington TypeBandwidth.BANDWIDTH_729 384 TypeLossyNetwork.LOSSY_NETWORK_USE_SYSTEM_DEFAULT
Also in the Device>Phone settings some field options come as
TypsStatus.STATUS_DEFAULT
TypePhonePersonalization.PHONEPERSONALIZATION_DEFAULT etc.
Y-
10-12-2007 03:33 AM
this looks like that you use not a english IE. I have the same problem if I use a german IE. After a change to the english one all looks fine.
Best regards Joerg
10-12-2007 04:22 AM
Just change the default language used by your web browser to EN-US.
Julien.
10-14-2007 10:14 AM
Bug CSCsk49799
