CallManager (7.x) not sending CDR to Billing Server
Hi All,
CallManager (7.x) not sending CDR to Billing Server. I am able to ping billing server from call manager.
CDR Load is also shoeing unsucessfull.
Please suggest how to troubleshoot this issue.
Thanks !
8 Replies 8
Jaime Valencia
Have you tried deleting and readding the server??
Was this working before??
java
if this helps, please rate
Jaime, Thanks for the reply.
No, I haven't tried deleting and readding the server because it was working earlier.
I have recied alert "No New CDR in the last 80 hours from server".
Checked, all services are UP.
Hi Amalraj,
Can u try restarting CDR Repository Managaer service in Call Manager ?
regds,
aman
Thanks Aman !
Is there any way to check on cucm that CDR has been sent to billing server successfully ?
Yes It's possible.
When CDR agent transfers CDR files to the Repository Node (PUB) they go into
"activelog/cm/cdr_repository/trans" folder.
Once the file transfer is completed, the file is moved to the temporary directory
activelog/cm/cm/cdr_repository/tmp
After that they go to activelog /cm/cdr_repository/preserve
//Files to be sent out and/or to be loaded by CAR
If CDRs are transfered sucesfully to all "billing destinations" they are moved to
activelog /cm/cdr_repository/processed
So you can take a look at processed folder to verify if a particular CDR file has been transferred or not
br,
Vadym
Hi ,
Please refer the below link. Very useful info.
https://supportforums.cisco.com/docs/DOC-5706
from where we can access these folders as mentioned by Vadym:
Thanks !
Go to Publisher CLI and type the following:
file list activelog /cm/cdr_repository/processed
// you will see the list of CDR files
to view a particular file you have to use file view activelog /cm/cdr_repository/processed/ ...
replace ... with the corresponding file name
Vadym
