Callmanager express - External tranfer to voice mail
michael.johnson
if anyone could help, i'm having problems when tranfering external calls, if unanswered they are not going to voicemail, internal ones are, if anyone knows the fix it would be appreciated
16 Replies 16
Brandon Buffin
Can you post your config and describe the call flow that fails - dialed number, etc.
Brandon
When external callers call in they are being transfered by the switchboard to the extension, if no one is available it should go to there voicemail
Version 4.1(0)
Cisco Unified CallManager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 10.10.4.1 port 2000
load 7910 P00403020214
load 7941 SCCP41.8-2-2SR1S
load 7960-7940 P00307020200
max-ephones 80
max-dn 80
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 5
dialplan-pattern 1 02076659... extension-length 4
voicemail 1000
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] GB (This is the default network locale for this box)
network-locale[1] GB
network-locale[2] GB
network-locale[3] GB
network-locale[4] GB
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line mode is single
moh music-on-hold.au
time-format 12
date-format dd-mm-yy
timezone 21 GMT Standard/Daylight Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30
timeout interdigit 4
timeout busy 10
timeout ringing 180
caller-id name-only: enable
system message PSL Group UK
web admin system name Admin
web admin customer name Customer
edit DN through Web: disabled.
edit TIME through web: disabled.
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 Apr 04 2008 10:39:35
transfer-system full-consult
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Can you post the rest of your config?
Brandon
sorry got distracted, just getting into Cisco Voice come from an Avaya background, and had this one passed on to me.
I have attached the config
What happens when the call is transfered and is unanswered? Fast busy? Wrong greeting?
Brandon
Brandon
michael.johnson
when its transfered it goes to the default message saying that there is no mailbox for this number, but it works on internal transfers
OK. This is due to a bug regarding the use of the dialplan-pattern command along with CUE. The dialplan-pattern command expands out the DN to the full E.164 number. For example, 9201 becomes 02076659201. CUE does not have a mailbox corresponding to this number, so the call fails. One way to work around this is with a translation rule.
voice translation-rule 1
rule 1 /02076659/ /9/
voice translation-profile 1
translate called 1
translate calling 1
translate redirect 1
dial-peer voice 1000 voip
translation-profile outgoing 1
Hope this helps. If so, please rate the post.
Brandon
michael.johnson
I have entered the following and it is still happening.
translate called 1
translate calling 1
I have double checked and this is only happening to external calls that are transfered.
I just noticed that you already had a voice translation rule named "1". There could be a conflict there. Can you post your config after the changes? Can you enable the following commands make the call the fails and post the output?
router#term mon
router#debug voip dialpeer
Brandon
michael.johnson
Morning, I have run a couple of traces and here are the resaults
Mike,
what is dial peer 9299 supposed to be doing?
I don't think you need it here.
Dragi
no still getting " there is no mailbox associated with this extension". this is only happening on transfered calls, any normal calls that dont get transfered go to voicemail.
