04-08-2010 09:51 AM - edited 03-15-2019 10:10 PM
Can anyone tell me where the
Callmanager name is used in version 5 and up.. During install a "CM_" is prefixed to the server name. Usually after the install we change the server name on the admin web page to the IP address however some of my peers change the "Cisco Unifed CM" fileds to match.
Usually I just leave it as "CM_" and server name.. I know in the past windows versions it didnt matter and in Linux versions it doesnt seem to matter either but I am curious as to what the name really does..
I know this is trivial but I stiil wonder why and what the field really does.
Hope this all makes sense
04-08-2010 12:17 PM
As far as I'm aware it's just an ID. Just like the MoH, CFB, etc have names; you can change it to whatever you like (doesn't have to have any particular prefix, and doesn't need to be related to the server if you don't want) and it will still work.
Aaron
Please rate helpful posts..
04-08-2010 03:30 PM
The CM Name is just an identifier that you give the server. When you want to look up a server, you can look it up based on a naming schema that you define.
The naming object that matters is the Server name. This is typically best set to IP address as opposed to host name.
Hailey
Please rate helpful posts!
