11-12-2013 10:02 AM - edited 03-16-2019 08:21 PM
Hi Guys,
I read the post with the same subject, but, the post is old. My Customer have a CUCM 8.6.2 install about VMWare 5.1 EsXi in the hardware DL-580 GL. I would like know if this solution is approved to install CUCM.
Thank You,
Wilson
Solved! Go to Solution.
11-12-2013 10:27 AM
You have to look at the 3rd-party server / specs-based column (at top) and walk through the requirements and links. All vendors are now supported; however, a given server must meet specs for various components. You need to know the details of what is in the HP server and compare to what is required to be supported. You won't see a list of "Server A" is supported, "Server B" is not.
Hailey
Please rate helpful posts!
11-12-2013 10:13 AM
Its a lot of info to look at but here's your starting point:
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware#.22Can_I_use_this_server.3F.22
Hailey
11-12-2013 10:22 AM
Hi Hailey,
Thanks for your attentation. I read the link, but, there is not mentioned about HP hardware supported.
Wilson
11-12-2013 10:27 AM
Hailey
