Calls fail with different access code
travisbarden
We have CUCM 8.6 and two providers: AT&T and Paetec. Paetec is local and LD. AT&T is international and has CLID blocked.
Normally our users use access code 9 to make a call and it goes out the approriate connection. If a caller needs to force CLID blocking (typically for security purposes) they use a different access code, say 55.
If a user places an international call with 55, the call fails. If the user dials the same number but with access code 9, the call succeeds. At this point Cisco and AT&T are pointing fingers at each other. The call setup looks the same.
This call was placed with 9 and it goes through:
030292: Sep 17 09:53:43.305 DST: ISDN Se0/2/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0171
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Net Specific Fac i = 0x00E1
        Calling Party Number i = 0x2081, '2125555555'
                Plan:Unknown, Type:National
        Called Party Number i = 0xA0, '011999999999999'
rtr06#
030293: Sep 17 09:53:43.369 DST: ISDN Se0/2/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8171
This call was placed with 55 and it fails:
030278: Sep 17 09:53:17.284 DST: ISDN Se0/2/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0170
                Standard = CCITT
        Net Specific Fac i = 0x00E6
030279: Sep 17 09:53:17.328 DST: ISDN Se0/2/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8170
        Cause i = 0x83BF - Service/option not available, unspecified
Thoughts?
paolo bevilacqua
Perhaps  you're using MGCP ?
and
I am not sure  (haven't searched) from where how and why CUCM configuration generates these facilities, perhaps related to CLID blocking.
I can tell you how to block CLID on a per-call basis, but that would be using dial-peer and H.323 or SIP, not MGCP.
I have looked at TR 41459
http://www.corp.att.com/cpetesting/pdf/tr41459_99.pdf
Ihese should be decoded according to
3.6.5.19 Network-Specific Facilities
table III - 43
1st case:
service SDN (including GSDN) access and egress
2nd case:
service ACCUNET Switched Digital Service (including Switched Digital International) access and egress
Now, still not knowing how CM is selecting the different service (I'm not expert with CM), you have to look at which one is right for your calls. And you may need to set the calling plan/type to be ISDN/national.
Note: in both cases you are not restricing calling party number
0x2081 =
Type of number = national number
Numbering plan identification = unknown
last octet of the description
Screening indicator = user provided, verified and passed
