Gateways types when register with h323 Gatekeeper
ahmad_tamneh
Level 4
Level 4
When we talked about the type of the gateway (as endpoint) that can register with cisco gatekeeper, the gateway can be register as one of the following types
VOIP-GW
H323-GW
TERMENAL
below the output of the command sh gatekeeper endpoint
My question here is what is the differance between each type of them and when we used each type of them??
orpHQ#sh gatekeeper endpoints
                    GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr  Port  RASSignalAddr   Port  Zone Name         Type    Flags
192.168.10.25   1720  192.168.10.25   33138 SEA              TERM
    H323-ID: TRUNK_GK_HQ_1
192.168.35.1    1720  192.168.35.1    60024 AMS               VOIP-GW
    E164-ID: 3000
    E164-ID: 3001
    H323-ID: CME
    Voice Capacity Max.=  Avail.=  Current.= 0
192.168.10.177  1720  192.168.10.177  54020 CUBE              H323-GW
    H323-ID: CUBE
Total number of active registrations = 3 orpHQ#sh gatekeeper endpoints
The answer to your question can be found with very little effort, have you even tried to google it?
Look at this page from my good friend Matthew Barry aka ciscovoiceguru, http://ciscovoiceguru.com/309/gateway-reg-type/
Response Signature
I saw it already,
How about terminal.
The type Terminal is used by end-points that register to a gatekeeper. For example a video conferens system.
Response Signature
