Calls going to VMX and not ever ringing I did not make any changes on.
tlawson
I came into work today and I keep gettng the message in my outlook that I have a new voicemail yet my phone never rang. i called from my cell and it went straight to voicemail.  my call forward or do not disturb is not on.  Can someone please help?
Thank you.
Toni
2 Accepted Solutions
No one mentioned DND.
DND and DNA are different things, if you're an end user you should be reaching out to your IT department for assistance.
java
if this helps, please rate
Thank you everyone I reached out to my IT department and someone changed my setting to go straight to vmx.
Have a great day!
6 Replies 6
Jaime Valencia
Use DNA and or debugs in your GW to find out what's the current call routing settings.
java
Good morning,
I am not clear on the acronyms what is DNA and GW?  I checked DND and it is not on.   However first ring is voicemail.
Looks Like call forward all enabled to Voicemail. As Jaime mentioned, use DNA to identify the call flow.
Response Signature
DND is not on I've checked several times.
java
Have a great day!
