Calls intermittently hit dead air
jeffshen1215
Hi All,
Our CUCM system (8.6) is experiecing a very strange issue: calls regardless internal or external intermittently hit dead air. Issue happens only when use speed dials, directory dials, redials. I checked the CDR and found the "called party number" of all failed calls in this format:
91XX@1xx.16.xx.1  (which is UCM server address)
91XXXX@1xx.16.xx.1
XXXX@1xx.16.xx.1  (if call internal)
* the number string before @ always are not the completely phone number dialed from (speed dial, directory, history logs)
Can anyone advise the direction of troubleshooting?
Thanks!
8 Replies 8
jeffshen1215
Bring it up see if anyone can offer an advise.
What do you mean with Dead air? If the problem is one way audio or not audio at all it could be a routing issue.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
As i know, it's not a routing issue. All issues happens in recent few weeks and we didn't change anything in CUCM.
Here is an example, when i call other extension by using "redial" or directory dial, most time the call get through and rings on the other extension, but intermittently the call just hang there, no ring back tone and eventually drop.
Hmmm. it could be some resources problem (DSP, CPU, Memory...). Have you find some new Alert or Warning? Log in RTMT, then go to Tools->Alert Central.
The server is fine according to the RTMI track. I suspect it's network connectivity related but need some guide to look into it.
Are you loosing packest between Phones and CUCM server? Check out the switch interface where phone/server are connected, maybe you're getting some mistmach speed or QoS issue (If QoS was applied on LAN).
Here is phone ststus one experienced issue, don't see the pack lost.
Rx totalPkt23440353
Rx crcErr00000000
Rx alignErr00000000
Rx multicast18370987
Rx broadcast02156169
Rx unicast02913197
Rx shortErr00000000
Rx shortGood00000000
Rx longGood00000000
Rx longErr00000000
Rx size6402596750
Rx size65to12718015848
Rx size128to25502447603
Rx size256to51100308818
Rx size512to102300067192
Rx size1024to151800004142
Rx tokenDrop00000000
Tx excessDefer00000000
Tx lateCollision00000000
Tx totalGoodPkt02814778
Tx Collisions00000000
Tx excessLength00000000
Tx broadcast00003068
Tx multicast00119601
LLDP FramesOutTotal00000000
LLDP AgeoutsTotal00000000
LLDP FramesDiscardedTotal00000000
LLDP FramesInErrorsTotal00000000
LLDP FramesInTotal00000000
LLDP TLVDiscardedTotal00000000
LLDP TLVUnrecognizedTotal00000000
CDP Neighbor Device ID
CDP Neighbor IP Address
CDP Neighbor IPv6 Address
CDP Neighbor PortGigabitEthernet5/41
LLDP Neighbor Device ID
LLDP Neighbor IP Address
LLDP Neighbor IPv6 Address
LLDP Neighbor Port
Port InformationFull, 1000
I recommend you use the switch console to see these error. What about server interface?
