Calls not able to route out of the local gateway
monasir
I am not able to place calls from my ucm phones to my pstn site.
What i did is the following:
I created routegroups, ( added my branch gateway in selected devices also the same thing for my hq router.
Created dial-peers in my hq router:
I am not able to call 911 to my pstn site, i created a routepattern in cucm which is pointing to my local gateway of cucm.
I'm hearing a busy tone., i am able to call from pstn to hq and branch sites.
In my hq and branch router if i debug i don't see nothing comes in.
I also created 2 calling party transformation patterns ( 1XXX and 5XXX)
I have to send a e164 format number to the pstn site. ( +1212394XXX) i also did this.
Voice translation rules also have been created.
But somethings goes wrong, i don't see the call arrives in the gateway when i debug isdn.
The strang part of this task is that i have to create a RL in cucm and point it to the created routed pattern (911)
When placing a call to the hq site i see its going true the branch1 gateway.
HQ router
HQ-RTR#sh run
Building configuration...
Current configuration : 3360 bytes
! Last configuration change at 12:46:03 PST Mon Jan 28 2013
! NVRAM config last updated at 12:45:36 PST Mon Jan 28 2013
version 12.4
hostname HQ-RTR
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone PST -8
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
no ipv6 cef
isdn switch-type primary-ni
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 911
rule 1 /^1/ /+1/
voice translation-profile ANI-OUT
translate calling 911
voice-card 0
archive
log config
  hidekeys
controller T1 0/2/0
pri-group timeslots 1-3,24
controller T1 0/2/1
interface Loopback0
ip address 10.10.110.1 255.255.255.255
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10 native
ip address 10.10.100.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 10.10.200.3 255.255.255.0
ip helper-address 10.10.210.10
h323-gateway voip bind srcaddr 10.10.200.3
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 10.10.210.1 255.255.255.0
interface FastEthernet0/1
no ip address
speed 100
full-duplex
interface Serial0/1/0
description network connection to Branch1 router
ip address 10.10.111.1 255.255.255.0
encapsulation ppp
ip ospf mtu-ignore
clock rate 64000
interface Serial0/1/1
description network connection to Branch2 router
ip address 10.10.112.1 255.255.255.0
encapsulation ppp
ip ospf mtu-ignore
clock rate 64000
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn outgoing display-ie
no cdp enable
interface Serial0/3/0
no ip address
shutdown
no fair-queue
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
disable-eadi
control-plane
voice-port 0/2/0:23
ccm-manager fax protocol cisco
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 5001 voip
destination-pattern 2123945...
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.210.10
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 911 pots
translation-profile outgoing ANI-OUT
destination-pattern 911
no digit-strip
port 0/2/0:23
forward-digits 3
sip-ua
retry invite 2
timers trying 300
gatekeeper
zone local PL proctorlabs.com
zone prefix PL 1... gw-priority 10 gk-trunk_2
zone prefix PL 1... gw-priority 9 gk-trunk_1
zone prefix PL 1... gw-priority 0 BR2-RTR
zone prefix PL 5... gw-priority 10 gk-trunk_2
zone prefix PL 5... gw-priority 9 gk-trunk_1
zone prefix PL 5... gw-priority 0 BR2-RTR
no shutdown
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line vty 0 4
exec-timeout 0 0
password cisco
login
transport input telnet
scheduler allocate 20000 1000
ntp source Loopback0
ntp master 5
ntp server 10.10.210.1
end
Branch1 router
BR1-RTR#sh run
Current configuration : 2818 bytes
version 12.4
hostname BR1-RTR
boot-start-marker
boot-end-marker
enable secret 5 $1$wNOA$XSwMLgrwkVM.XnurXmwyJ.
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain name proctorlabs.com
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
controller T1 0/2/0
pri-group timeslots 1-3,24 service mgcp
controller T1 0/2/1
interface Loopback0
ip address 10.10.110.2 255.255.255.255
ip ospf network point-to-point
ip address 10.10.210.16 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
switchport trunk native vlan 130
switchport mode trunk
switchport voice vlan 240
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
no ip address
encapsulation hdlc
isdn bind-l3 ccm-manager
no cdp enable
ip address 10.10.111.2 255.255.255.0
encapsulation ppp
ip ospf mtu-ignore
interface Serial0/3/1
no ip address
clock rate 2000000
interface Vlan1
no ip address
interface Vlan130
ip address 10.10.101.1 255.255.255.0
interface Vlan240
ip address 10.10.201.1 255.255.255.0
router ospf 1
no ip http server
disable-eadi
control-plane
voice-port 0/2/0:23
ccm-manager switchback immediate
ccm-manager redundant-host 10.10.210.10
ccm-manager mgcp
mgcp
mgcp call-agent 10.10.210.10 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
gatekeeper
shutdown
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
password cisco
login
transport preferred none
line vty 5 15
exec-timeout 0 0
privilege level 15
logging synchronous
no login
end
do not use any thing in Router pattern , use default , use route list ( rl-local-gw)..
cheers
Amim
Note:Rate if you find useful.
16 Replies 16
Chris Deren
What version of CUCM are you using and what is Dialed Number Analyzer showing?
Have you tried "debug voice dialpeer"?
Chris
Hi Chris,
I'm using version 8.
I don't see anything comes in the gateway.
I haven't used DNA yet.
mohamed
You need to create Route list , and that need to be mapped with local standard route group and that need to maped with devcie pool , and in route pattern you need ti use that route list .
Rgds
amim
Hi Amim,
What i did was the following:
Created 2 routegroups (HQ and BR1)
Added the h323 gateway and the br1 gateway in the selected devices.
Then i created a routelist ( rl-local-gw)
Then i created a routepattern (911)
This routepattern is mapped to the above routelist
After that i've applied the routelist at both devicepools (HQ, BR1 devicepools)
Created css & partitions.
2 calling transformations patterns  ( 1XXX & 5XXX )
After that i created voice translations rules as i've mentioned in my above post.
But still after al my configurations i don't see anything comes in my HQ router, you don't see the call comes in my router if
i do a debug isdn q931 nothing comes in.
What are you dialing? Are you dialing 911? You mention adding RG to DP, so are you using local route group feature on other route patterns?
Go to serviceability page and find Dialed Number Analyzer and use to to see what CUCM is doing, this is very simple tool that will show you what is going on.
HTH,
Chris
I'm dialing 911
Yes that's true, i'm using local routegroup.
When i create a routelist, i'm adding standard local route group.
I'm going to try the dna.
HI,
in H323
use this
voice translation-rule 1
rule 1 // // type any unknown plan any isdn
voice translation-rule 2
rule 1 /^XXX/ /XXXXXX$/ type any national plan any isdn
where X is any isdn
Voice translation-profile 911
translate calling 2
translate called 1
translation-profile outgoing 911
no digit-strip
port XXXXX
and in route list , first prefrence give standard local route group , then go to device pool , and in local route group select
BR1 Route Group
then check
Amim
cheers
Amim
Thank you,
I'm going to try this when i'm at home.
Amim,
Please review his responses, he is using Local Route Group feature.
Chris
Yes cris , thats why   i told him to go to device pool , and i in local route group , slect BR1 Route Group., it will work as in locla route group , gateway is bidned with device pool of BR1 , so every time 911 calls will only use BR1 gateway.
rgds
Amim
Hi Guys,
It worked.
I've only changed something in my routepattern (911)
I didn't select anything on my routepartition ( nowe i have "none")
Before i had a partition called " pt-nanp-911 "
Very strange, the book is explaining that you could put it in a partition in case we had phones in other dialing domains
registered to UCM which should not be able to dial 911.
Can someone please explain this to me?
Guys Thanks anyway for such the great help!
Apparently your phone's CSS does not have access to this partition, having patterns/DNs in none partition is a very bad practice which will lead your deployment to run into many limitations, it is especially bad when you have remote sites as now you have no controll over which site calls go out of.  If you do not understand partitions and CSSes I suggest you read the SRND and system guide as that is the most fundamental items in CUCM.
HTH, please rate all useful posts!
Chris
Hi Chris,
Thanks for your advise.
By the way this is for lab purposes not a real live environment.
