01-29-2013 03:41 AM - edited 03-16-2019 03:25 PM
Hi!
I have one IP Phone 6921 which everydays shows ´ IP released´ and user must to restart the IP Phone to get it run. There is the only which fails in the site. I changed the IP Phone and the cable and still fails.
Any idea what could be this issue?
Thanks!
01-29-2013 03:48 AM
These are logs from the IPPhone, shows it continually
[14:24:08, 01/28/2013] SEP2c542d6aac92 Get ip from DHCP server : 192.168.6.38
[14:23:53, 01/28/2013] ROOT: Hardware ringer :FALSE
[14:23:53, 01/28/2013] Network: nw_create() ipstack_mode=2
[14:23:51, 01/28/2013] system boot up (SCCP 9.3.1.3)
[18:02:47, 01/23/2013] SEP2c542d6aac92 Get ip from DHCP server : 192.168.6.38
[18:02:33, 01/23/2013] ROOT: Hardware ringer :FALSE
[18:02:33, 01/23/2013] Network: nw_create() ipstack_mode=2
[18:02:30, 01/23/2013] system boot up (SCCP 9.3.1.3)
01-29-2013 05:56 AM
Hi Ivan,
Try upgrading the phone firmware to the lastest version. Look ;like is not a DHCP issue because only this phone is getting the IP release.
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
01-30-2013 03:08 AM
Hi!
Thanks for your answer but it can not be the solution because all ipphones has already last firmware installed, SCCP69xx.9-3-1-3 and only appears the failure it one ipphone.
regards.
01-30-2013 03:41 AM
I would check on the DHCP server against that MAC address to see if you are getting any issues.Also check the length of the lease the phone is getting.
cheers
Mark
