12-20-2010 04:44 AM - edited 03-16-2019 02:30 AM
At our remote sites we have cisco 2801 routers with VIC2-2FXS cards for the voice. This is plugged into a 2+8 PBX system locally with analogue phones connected.
Since we have upgraded the IOS from version c2801-advipservicesk9-mz.124-21.bin to c2801-advipservicesk9-mz.124-24.T4.bin the phones occasionally fail to clear down and the only wat to resolve is to reload the router. Anyone have any ideas?
voice-port 0/0/0
output attenuation -3
cptone GB
timeouts wait-release 3
connection plar 5127
voice-port 0/0/1
shutdown
dial-peer voice 1 pots
destination-pattern 4127
port 0/0/0
dial-peer voice 10 voip
destination-pattern 5127
session target ipv4:130.10.6.1
dtmf-relay h245-signal
no vad
ow-A-28EVR#sh voice port 0/0/0
oreign Exchange Station 0/0/0 Slot is 0, Sub-unit is 0, Port is 0
Type of VoicePort is FXS VIC2-2FXS
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to -3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 64 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 250 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is plar
Connection Number is 5127
Initial Time Out is set to 10 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Supervisory Disconnect Time Out is set to 750 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 3 s
Companding Type is u-law
Region Tone is set for GB
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Ring Frequency is 25 Hz
Hook Status is On Hook
Ring Active Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Hookflash-in Timing is set to max=1000 ms, min=150 ms
Hookflash-out Timing is set to 400 ms
No disconnect acknowledge
Ring Cadence is defined by CPTone Selection
Ring Cadence are [4 2] [4 20] * 100 msec
Ringer Equivalence Number is set to 1
12-20-2010 05:39 AM
12.4T has exibhited many bugs for voice. Try 15.0(1)M4, or go back to what you had before.
12-21-2010 06:29 AM
The problem is only on 6 sites out of a hundred. We are going to try the 15
.0(M) IOS and see if that solves it
I can also clear the fault using the command
router#clear call voice causecode 17 calling-number 4354
the causecode can be seen on the #show call active voice command and the phone number is the local one
