calls not working on a FXS port
Hi, i have this issue for a few days and i didnt found any explanation
fxs port ----> remote gateway -----> cm 4.2 ---- > isdn gateway
when i place a call, i believe that the call doesnt leave the remote gateway, since i cant see it on the isdn gateway with a debig isdn q931
when i run a debug voip ccapi inout on the remote gateway i can see a disconnect cause 38, but i can ping all the devices, and many other calls are goint out throught the isdn gateway.
This is the sh run, am i missing something?
rmagma161#sh run
Building configuration...
Current configuration : 8568 bytes
version 12.4
service timestamps debug datetime
service timestamps log datetime msec localtime
hostname rmagma161
boot-start-marker
boot-end-marker
logging message-counter syslog
enable password cisco
no aaa new-model
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.52.30.0 10.52.30.10
ip dhcp pool BOULANGER
   network 10.52.30.0 255.255.255.0
   option 150 ip 85.63.56.104 85.63.56.105
   default-router 10.52.30.1
no ipv6 cef
isdn switch-type basic-net3
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
no supplementary-service h450.2
no supplementary-service h450.3
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  h225 timeout setup 30
  h245 caps suppress nte
voice class codec 1
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 3 g711alaw
codec preference 4 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 6
rule 1 /17610/ /911789550/
rule 2 /17611/ /911789551/
rule 3 /17612/ /911789552/
voice translation-rule 110
rule 1 /911789550/ /17610/
rule 2 /911789551/ /17611/
rule 3 /911789552/ /17612/
voice translation-profile SPZ-ALCORCON
translate calling 6
voice translation-profile WORTEN-MOVILES
translate calling 110
voice-card 0
archive
log config
  hidekeys
ip tftp source-interface Loopback0
interface Loopback0
description --- Administration ---
ip address 90.167.44.4 255.255.255.255
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.2
description RED DATOS
encapsulation dot1Q 2 native
ip address 10.130.76.1 255.255.255.0
ip helper-address 10.10.1.247
no cdp enable
interface FastEthernet0/0.3
description RED WIFI
encapsulation dot1Q 3
ip address 10.121.76.1 255.255.255.128
no cdp enable
interface FastEthernet0/0.4
description RED WIFI2
encapsulation dot1Q 4
ip address 10.121.76.129 255.255.255.192
interface FastEthernet0/0.5
description RED WIFI3
encapsulation dot1Q 5
ip address 10.121.76.193 255.255.255.192
interface FastEthernet0/0.152
description RED VOZ
encapsulation dot1Q 152
ip address 10.52.30.1 255.255.255.0
no cdp enable
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
description VPN - WORTEN ESPAQA DISTRIBUCION S.L. - ADS0976727 - WOM 193620
ip address 90.167.45.18 255.255.255.252
atm route-bridged ip
pvc 1/33
  protocol ip 90.167.45.17
  no oam-pvc manage
  encapsulation aal5snap
interface BRI0/2/0
no ip address
isdn point-to-point-setup
interface BRI0/2/1
no ip address
interface BRI1/0
no ip address
encapsulation hdlc
shutdown
interface BRI1/1
no ip address
encapsulation hdlc
shutdown
interface BRI1/2
no ip address
encapsulation hdlc
shutdown
interface BRI1/3
no ip address
encapsulation hdlc
shutdown
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 90.167.45.17
ip route 85.62.225.221 255.255.255.255 90.167.45.17 name tftp_server
ip route 195.6.0.26 255.255.255.255 90.167.45.17 name wasac_server
no ip http server
no ip http secure-server
access-list 1302 permit 195.6.0.26
access-list 1302 remark Lista Acceso Gestion
access-list 1302 permit 10.118.213.168 0.0.0.3
access-list 1302 permit 10.118.245.200 0.0.0.7
access-list 1302 permit 62.36.193.64 0.0.0.63
snmp-server trap-source Loopback0
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps bgp
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
control-plane
voice-port 0/1/0
cptone ES
station-id number 911789550
voice-port 0/1/1
cptone ES
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
ccm-manager fax protocol cisco
mgcp fax t38 ecm
dial-peer cor custom
name Internas
name FijosNacional
name Moviles
name Internacional
dial-peer cor list LlamarInternas
member Internas
dial-peer cor list LlamarNacional
member Internas
member FijosNacional
dial-peer cor list LlamarMoviles
member Internas
member Moviles
dial-peer cor list LlamarInternacional
member Internas
member Moviles
member Internacional
dial-peer voice 1 voip
description CCM
incoming called-number 1761.
dial-peer voice 21 voip
corlist outgoing LlamarNacional
description CCM1
preference 2
destination-pattern 0[8-9]........
session target ipv4:85.63.56.105
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
no vad
dial-peer voice 22 voip
description CCM2
preference 1
session target ipv4:85.63.56.104
no vad
dial-peer voice 31 voip
corlist outgoing LlamarInternas
description CCM1
preference 2
destination-pattern [12]....
no vad
dial-peer voice 32 voip
description CCM2
preference 1
no vad
dial-peer voice 41 voip
corlist outgoing LlamarMoviles
description CCM1 Moviles
translation-profile outgoing WORTEN-MOVILES
preference 1
destination-pattern 06........
no vad
dial-peer voice 42 voip
description CCM2 Moviles
preference 2
no vad
dial-peer voice 51 voip
corlist outgoing LlamarInternacional
description CCM1 Internacionales
preference 2
destination-pattern 000T
no vad
dial-peer voice 52 voip
description CCM2 Internacionales
preference 1
no vad
dial-peer voice 43 voip
preference 2
destination-pattern 07[1-9].......
no vad
dial-peer voice 44 voip
preference 1
no vad
dial-peer voice 300 pots
corlist incoming LlamarInternacional
answer-address 911789550
dial-peer voice 302 pots
answer-address 911789552
dial-peer voice 400 pots
destination-pattern 17610
port 0/1/0
prefix 17610
dial-peer voice 402 pots
destination-pattern 17612
port 0/1/1
prefix 17612
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.52.30.1 port 2000
max-ephones 24
max-dn 48 dual-line
transfer-pattern 09........
transfer-pattern 08........
transfer-pattern 06........
transfer-pattern 26...
keepalive 20
time-format 24
date-format dd-mm-yy
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
rmagma161#
Anas Abueideh
Engager
Engager
can you make debug dialpeer on the remote gateway, and check what dialpeers matches the dialed-numbers and where it stucks.
disconnect cause 38 means that the network is out of order, it seems it is related to dialed-number matching and corlist. also try to remove corlist or create one without corlist to make your test.
Anas
please rate if it is helpful
Recognize Your Peers
