Showing results forĀ
Search instead forĀ
Did you mean:Ā
Calls show as blocked or restricted.
Tomas Mazur
When calling cells in US sometimes our company number shows as blocked or restricted.
Our topology is
CUCM 9.1 <-> 2921 VG 15.2(4) <-> T1 PRI
Our telco advised to make sure we have parameters assigned to our PBX:
In order for caller ID number to be delivered to cell carriers these 3 calling parameters needs to be set in your PBX.
It may work sometimes w/o these parameters but the only way to GUARENTEE CID number delivery to cells is if the PBX has these 3 parameters populated.
Nature of address indicator ANSI: Unique national (significant) number
Numbering plan indicator: ISDN (Telephony) numbering plan (Recommendation E.164)
Screening indicator: Reserved for ā€˜User Provided, Passed Network Screening’
These are your current settings in your PBX.
Calling party number parameter
Parameter name 10 Calling party number
Length indicator 7 $07
Odd even indicator 0 even
Nature of address indicator                            0
Spare 0 –
Numbering plan indicator                               0
Address presentation restricted indicator 0 presentation allowed
Screening indicator 1                                      user provided, screening passed
Address signals 618615098
Should I configure these on the 2921 voice gateway or in Call Manager? IS anyone familiar with the particular config required here?
thanks
T
5 Replies 5
Jaime Valencia
That depends, is this MGCP or H.323??
You can also debug your GW as it is right now, and see what you're sending.
java
if this helps, please rate
Hi Jaime,
It is MGCP
config
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn map address ^011 plan unknown type unknown
isdn bind-l3 ccm-manager
no cdp enable
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.10.10.10
ccm-manager config
mgcp
mgcp call-agent 10.10.10.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package fxr-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
Tom
Chris Deren
Provide "debug isdn q931" for one of these calls.
Hi Chris
375718: Dec 21 17:53:09.016: %IPPHONE-6-REGISTER_NEW: ephone-29:SEP2C3F38C838FF IP:10.1.102.11 Socket:15 DeviceType:Phone has registered.
375719: Dec 21 12:53:52.068: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0B53
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0081, '6176140715'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '17816083481'
375720: Dec 21 12:53:52.392: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8B53
375721: Dec 21 12:53:53.360: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8 callref = 0x8B53
Progress Ind i = 0x8488 - In-band info or appropriate now available
375722: Dec 21 12:54:22.529: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x0B53
Cause i = 0x8090 - Normal call clearing
375723: Dec 21 12:54:22.577: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x8B53
375724: Dec 21 12:54:22.597: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0B53
375725: Dec 21 17:55:49.661: %IPPHONE-6-UNREGISTER_NORMAL: ephone-29:SEP2C3F38C838FF IP:10.1.102.11 Socket:15 DeviceType:Phone has unregistered normally.
Does this help?
Tom
Tomas Mazur
In the end we have configured it on the CUCM as it is a MGCP gateway and controlled from the server rather than gateway.
Now all calls pass full number and locality on both landlines and molife phones.
Our final settings after few hours of testing in the picture below:
enter image description here
