Can a Cisco phone make calls via router to a residential phones
John Cheetley
Level 3
Level 3
Example
10 cisco phones behind a CME router in a business to a residential phone in the outside world?
Do all connections need to be router based?
And how does an ISP communicate to a Cisco router using DID?
And does the ISP have to give certain information to the client in order for the clients Cisco phone calls to be connected?
You can configure a dial-peers as below for outgoing calls:
dial-peer voice 1 pots
 destination-pattern 9T       (this will route all calls to FXO and here 9 as a access code)
 port 0/1/2                           (this is port where FXO has connected at router)
You can refer below link and CME admin guide as well for further understanding.
https://learningnetwork.cisco.com/thread/52311
Suresh
6 Replies 6
Suresh Hudda
To connect calls to outside world basically you need to have some type of trunk (E1/T1/FXO/SIP Trunking) between ISP & CME router and when you will have this then you will get a DID from service provider and you can use these to connect with outside world's phones.
And for this you need to create dial-peers in CME to route external calls to trunk/ISP.
Hope this helps.
Suresh
Thanks Suresh for this.
Is there a procedure Cisco has for this please as I have contacted my ISP and all they gave me was a DID number.
What connectivity you have got/bought from ISP ?, i means is it e1 or T1 or FXO or SIP Trunking ?
Suresh
FXO
Suresh
Thanks Suresh. I have done this already
