11-11-2015 02:31 AM - edited 03-17-2019 04:52 AM
but in many documents I saw supported other not supported ??
GV
Solved! Go to Solution.
11-11-2015 02:41 AM
Hi GV,
Its listed in the "SIP Phone Models Validated for CME using Fast-track Configuration". If you are not getting the phone type 7811, use the fast track configuration as mentioned in the below link.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.pdf
Rajan
11-11-2015 02:41 AM
Hi GV,
Rajan
11-11-2015 04:21 AM
So, based on this document pdf. I can configure cisco ip phone 7811 on cme 10.5 ??
with this configuration:
11-11-2015 07:28 AM
Yes. you can with that fast track configuration.
11-11-2015 07:40 AM
Thnaks a lot but ,
I saw many topics it said if you go with fast track u lost features ? callfrw callpickup ?
do i loose any features if i go with fast track configuration
THANKS a lot,
GV
11-11-2015 08:38 AM
03-30-2016 08:42 AM
Dear Sir,
We have two Sites .example site A and Site B.call manager Bussiness Edition 6000 is placed in site-A and Site-B phones are registered on this BE 6000 through VPN.In Site-B there is a SRST Router for the redundancy
In site-B there is cisco 7975,7962 ,cp 6921 and cp7861 iphones
After finishing the configuration 7675 and 7962 is able to register on srst router after loss the connectivity of BE 6000.but cp 6921 and cp7861 iphones are not registering on srst router.Please help me
Find the configuration SRST Router Configuration. Please let me know if i should make changes,Because this is the first time im doing this.please help me
version 15.4
hostname AUH_SRST
ip dhcp pool VOICE
import all
network 192.168.50.128 255.255.255.128
default-router 192.168.50.130
option 150 ip 10.10.3.251 10.10.3.250
lease 30
no ip domain lookup
trunk group AUH_FXO
hunt-scheme round-robin
cts logging verbose
crypto pki trustpoint TP-self-signed-2478824890
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2478824890
revocation-check none
rsakeypair TP-self-signed-2478824890
crypto pki certificate chain TP-self-signed-2478824890
certificate self-signed 01
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice iec syslog
voice register global
mode srst
voice translation-rule 1
rule 1 /[0-9]+/ /9&/
rule 2 /971/ /900971&/
voice translation-profile FROM_ISP
translate calling 1
application
global
service alternate default
license udi pid CISCO2921/K9 sn FCZ193661MR
hw-module pvdm 0/0
username admin privilege 15 password 0 admin
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description #MANAGEMENT#
encapsulation dot1Q 10
ip address 192.168.22.5 255.255.255.248
interface GigabitEthernet0/0.60
description #vOICE vLAN#
encapsulation dot1Q 60
ip address 192.168.50.130 255.255.255.128
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.50.130
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.50.129
logging trap debugging
control-plane
voice-port 0/0/0
trunk-group AUH_FXO
translation-profile incoming FROM_ISP
cptone AE
timeouts call-disconnect 5
timeouts wait-release 5
timing guard-out 1000
connection plar opx 5333
caller-id enable
voice-port 0/0/1
trunk-group AUH_FXO
cptone AE
caller-id enable
voice-port 0/0/2
trunk-group AUH_FXO
cptone AE
caller-id enable
voice-port 0/0/3
trunk-group AUH_FXO
cptone AE
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 pots
incoming called-number .
dial-peer voice 1000 voip
destination-pattern 5333
session target ipv4:10.10.3.250
voice-class codec 1
dial-peer voice 1001 voip
destination-pattern 53..
voice-class codec 1
sip-ua
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 192.168.50.130 port 2000
max-ephones 25
max-dn 50 dual-line
system message primary MELCO_LOCAL
system message secondary MELCO_LOCAL
transfer-pattern .T
keepalive 20
call-forward pattern .T
call-forward busy 5333
call-forward noan 5333 timeout 45
time-zone 35
date-format dd-mm-yy
