03-12-2019 01:56 AM
Dear All ,
can I setup a conference call between many participants then exit without disconnect the call?
I am using CUCM 12.1
Solved! Go to Solution.
03-12-2019 02:06 AM
Check cucm cluserwide paramters ' features ' conference. You have the option to drop qhen organiser leaves. Or when no on net party remains
03-12-2019 02:29 AM
Hi!
If you are referring to an Ad-Hoc Conference, you may go to CUCM Administration Page->Service Parameters->Select the CUCM Server->Call Manager Service.
Then, at Clusterwide Parameters (Feature - Conference), you may check the Defaulf value (Never):
Never - The conference remains active a) after the conference controller hangs, and b) after all OnNet parties hang up. Be aware that choosing this option means that if OnNet parties conference in OffNet parties and then disconnect, the conference stays active between the OffNet parties, which could result in potential toll fraud.
Other options are:
When Conference Controller Leaves - Terminate the conference when the conference controller hangs up or when the conference controller transfers, redirects, or parks the conference call and the retrieving party hangs up.
When No OnNet Parties Remain in the Conference - Terminate the conference when there are no OnNet parties remaining in the conference.
George
03-12-2019 02:06 AM
03-12-2019 02:29 AM
Hi!
Other options are:
George
03-12-2019 04:43 AM
